1 - 3 of 3 Posts
Have a 2019 Ascent. Air is cold on passenger side but not on drivers side regardless of how cold I set it. This is just a recent situation. Any ideas?
Have you ensured that "Sync" is enabled or that the passenger side setting is also set to low? The Ascent is three zone, and you should have 2 or 3 temperature settings on the display (only two if rear climate control is off). If the passenger zone is also set to low, it sounds like a damper or heat exchange valve may be stuck, and you'd need to bring it in for service.
Service has been scheduled
1 - 3 of 3 Posts
