1 - 15 of 15 Posts
2019 Ascent Premier
Nope!
I installed in the afternoon and all went smooth. Drove the car a few times and haven’t noticed any difference. Probably just map updates and maybe some bug fixing.
by the way, I also looked for the release notes and found nothing, so if anyone has it or knows how to get it, publishing here would be very appreciated
The only change I have noticed is that the weather alerts now take up the entire screen rather than a small popup.
And they are now user selectable as someone has already pointed out.
I didn't see any notes anywhere about this update.
I also seem to be getting the same alert every 15 to 20 minutes now. I've tried dismissing the alert using both the [back] button and the [X] button. But the alerts still come back.
I'm wonder if there is a way to determine if this is Sirius rebroadcasting the alert, or a change in the head unit software behavior. Either way, it's annoying.
My Android Auto doesn't work after the update. It will connect, show a blank screen, then disconnect. Any thoughts?
I had to reconfigure the app, I think the head unit deleted the record when it updated. Plug it in, let it go thru and disconnect and then start the android auto app on your phone, follow the prompts and it should come right up.
Do you have the latest map update, published 12/17/2019? They added a setting to the xm/sirius radio where you can now control the alert types you receive.
Any tips to get the software to update over WiFi? Mine says it's up to date, but I'm on 19.01.70
WiFI is the only way to update over the air...
I was trying with WiFi....just says no update available.
This is not yet available to Navigation units as an OTA update. :(
Eh? The photo shows a Navi system. Or you mean I have to use a USB stick and do it manually?
Apologies, there's no over the air update available for this update for navigation units yet - just the manual USB update currently.
1 - 15 of 15 Posts
