1 - 8 of 8 Posts
Navigation is dead on our 21 Touring. It “lost” a favorite that I programmed yesterday when I touched it to navigate to. tried voice and it told me “this feature is not active in my country”. Retried and said “cancelled”. Tried another favorate and “navigation can not be completed”. now all I have is a white screen with the blue position sensor.
Phone was also wonky but seems OK now.
Apple car play seems OK
Have appt tomorrow with dealer.
Is there a reboot/reset I should try. Nav is like adaptive cruise, don’t realize how much you use it.
Thanks, Bob
Did the reset and no change. I was hoping for a reboot of some kind- this wasn’t it.
If you didn't see the whole screen flicker, go blank, and then boot to the Starlink logo, you did not hold the button long enough. Just try again, hold until you see those things happen, then let go.
Wiping everything and starting again is done in the head unit, under Settings->General, where you will find a "restore" function (I don't remember the exact location - if you can't find it, let me know).
Also, what firmware version are you running?
  • Settings->General->System Information
Follow Up: Dealer tried the reset-no difference. He hit the tuner button several times with another button - I think a shortcut to some menus. They reinstalled the Nav system software, and no help. Then they reinstalled all the maps- which solved the issue. Everything is working as before. He said get a USB drive and download via computer, don’t use WiFi. The maps didn‘t seem to load properly. Maybe if I drove into an area that I didn’t update, it may have worked.
The version you installed didn't have maps. 20.41.70 is the maps version. Something must have downloaded or updated improperly. Happens every now and then. Wish I'd understood what the problem was you were having. My mistake - I thought you were saying the whole screen was going white - not the navigation component. Sorry about that. Installing 20.41.70 from subaru-maps.com would have resolved it. Also, deleting and re-downloading a region often works.
Anyway, glad they got you up and running again.
1 - 8 of 8 Posts
