1 - 20 of 27 Posts
I was just assuming and just realize, can anyone confirm that if I didn't get a touring or add the panoramic moon roof I won't getting any moon roof? even the regular moon roofs found on other cars?
Pretty sure it's the big one or nothing.
Reactions: zhingket
Those Panoramic sunroofs look great, but I just cannot let myself pull the trigger on something that is designed to fail right after the warranty expires. I don't like water on the inside of my vehicle.
I've had sunroofs for my entire adult life and have never had one leak.
I have the same experience with sunroofs, but I do know the GMC Acadia had issues with their sunroofs in their first year models...'08 I believe. They would leak and water ran down the inside of the panels ruining the electrical components. Still, I'm not too worried about our Ascent. **** happens and hopefully that's why you have a warranty.
All moon/sun roofs will leak a little bit, but they are now designed to direct that water flow through channels out of the car. They no longer allow water to get in and ruin things.
Just a quick addendum to that. In the corners of the open sunroof, there are little tubes that go down through the A and C pillars, so the water that DOES get around the edges can drain away. If you do a lot of driving is a dusty environment, or have your roof open in the fall to enjoy the leaves changing colors and then those leaves fall in there ... clean the tubes out every two or three years. You know, one of those ten minutes of preventative maintenance instead of a putting in a new headliner later. (And if I have to tell you how to use a pipe cleaner or air compressor to blow debris out of a channel ... take it in to someone who DOES.)
I’m talking of panoramic full length glass roofs. Normal sunroofs don’t leak because people rarely use them. Time will tell on these large pieces of glass. KIA discontinued them because of problems. I hope no one has a problem.
Just like all these complicated electrical systems. Instead of the money light going on, it will be the mega money light.
KIA still offers panoramic moonroofs and we’ve never had an issue with ours
Regularly clean the drain channels and tubes, or take it some place that can do it.
When the drain channels and/or tubes get clogged, they leak and/or rust.
Is the moonroof supposed to open its entire length to open air, or only the front half?
Just the front half. There's no room in the roof for the entire thing to retract so they double up over the rear section.
Reactions: calimomofboys
1 - 20 of 27 Posts
