Hello,
I got this issue in Sep last year. It started with the version 19.2.
I used W10 Virtual machine in Virtualbox, that was working just fine with Map Downloader V 19.1. When V 19.2 was published, it auto-updated itself, and stopped with this message. I tested also with new W10 installation on a physical laptop with the same success.
Here are the details about the error:
warning [2020.09.05 8:18:56.865] [unknown(0)] - Model size of -2 is less than 0
debug [2020.09.05 8:18:56.926] [onCompleted(25)] - Screen.pixelDensity: 3.777988677988678, Screen.logicalPixelDensity: 3.7795275590551185
info [2020.09.05 8:18:56.926] [Updater::startCheckForUpdates(30)] - Updater(0x8492f58) START
info [2020.09.05 8:18:56.949] [Updater::startCheckForUpdates(43)] - Updater(0x8492f58) END
info [2020.09.05 8:19:00.984] [Updater::checkForUpdatesFinished(66)] - Updater(0x8492f58) START ""
debug [2020.09.05 8:19:00.984] [onNewUpdatesAvailable(11)] - Update available: false
info [2020.09.05 8:19:00.985] [LoginManager::autoLogin(20)] - START LoginManager(0x32abea8)
info [2020.09.05 8:19:00.985] [LoginManager::autoLogin(31)] - END LoginManager(0x32abea8)
info [2020.09.05 8:19:00.985] [Updater::checkForUpdatesFinished(82)] - Updater(0x8492f58) END
info [2020.09.05 8:23:47.388] [LoginManager::login(36)] - START LoginManager(0x32abea8)
info [2020.09.05 8:23:47.408] [SecurityContext::setAuthenticationState(74)] - new AuthenticationState: SecurityContext::AuthenticationInProgress
info [2020.09.05 8:23:47.430] [LogInCommand::run(20)] - LogInCommand(0x8ab3450) START
info [2020.09.05 8:23:47.431] [LogInCommand::run(26)] - LogInCommand(0x8ab3450) url "
https://subaru-maps.com/oauth/token" postData "grant_type=password&client_id=client1&
[email protected] &password=zzzzzzzzzzzz"
info [2020.09.05 8:23:47.439] [LogInCommand::run(30)] - LogInCommand(0x8ab3450) END
info [2020.09.05 8:23:47.439] [LoginManager::login(75)] - END LoginManager(0x32abea8)
warning [2020.09.05 8:23:47.546] [unknown(0)] - QSslSocket::connectToHostEncrypted: TLS initialization failed
warning [2020.09.05 8:23:47.565] [AbstractNetworkCommand:
nFinished(97)] - LogInCommand(0x8ab3450) Error code: QNetworkReply::UnknownNetworkError , error string: "TLS initialization failed"
warning [2020.09.05 8:23:47.566] [AbstractNetworkCommand:
rocessError(49)] - Response: ""
info [2020.09.05 8:23:47.566] [LoginManager:
nError(147)] - LoginManager(0x32abea8) "Problem contacting server. Please check your network connection." "99: TLS initialization failed"
i
nFinishedLogOut(140)] - LoginManager(0x32abea8)
info [2020.09.05 8:23:47.566] [SecurityContext::setAuthenticationState(74)] - new AuthenticationState: SecurityContext::NotAuthenticated
debug [2020.09.05 8:23:47.566] [showErrorMessage(20)] - Problem contacting server. Please check your network connection. 99: TLS initialization failed
info [2020.09.05 8:24:35.552] [VehicleManager::clear(177)] - VehicleManager(0x1e1250) START
info [2020.09.05 8:24:35.552] [VehicleManager::clear(186)] - VehicleManager(0x1e1250) END
info [2020.09.05 8:24:35.552] [DownloadManager::stopAllDownloads(86)] - DownloadManager(0x32ab118) START
info [2020.09.05 8:24:35.552] [DownloadManager::stopAllDownloads(93)] - DownloadManager(0x32ab118) STOP
info [2020.09.05 8:24:35.552] [InstallationManager::abortAll(130)] - InstallationManager(0x32ad070) START
info [2020.09.05 8:24:35.552] [InstallationManager::abortAll(140)] - InstallationManager(0x32ad070) END
critical [2020.09.05 8:24:35.552] [SecurityContext::getUserId(39)] - Reading user ID but no user details, state: SecurityContext::NotAuthenticated
I wrote to the local representative with these details, but the only answer I got i:
Thank you for your information.
We have forwarded your e-mail to the manufacturer.
As soon as we receive further information, we will inform you
Last maps update I did using an old laptop running W7, that worked just fine.
I've just RE: the mail asking for news.
Will update here once I get something.
Cheers.
