1 - 18 of 18 Posts
2020 Blue Ascent Premium
Hi All,
The family and I are driving to Michigan from Washington State this summer (about 2300 miles one way). I’m still undecided if we should tow our Winnebago Micro Minnie 2100BH with us. I basically keep the Ascent between 2000 and 3000RPM and between 55 and 65 mph (Slower on the hills of course). I’m worried that the distance might be too much, but once we get past the Rockies it’s pretty flat.
I know the Ascent isn’t meant to be strictly a tow vehicle, but I waned to see if anyone on here had any thoughts. Do you think this is too far to drive with a 4000lb trailer? Would it be overkill to get the transmission fluid flushed (we have 17,000 miles on the car) to keep fresh fluid in it for the trip?
Thanks in advance for all your input!
11808
Should be fine towing within the rated capacity. Trans flush would be overkill. Gas mileage will not be pretty, if you are not staying long the economic trade off between gas mileage and lodging should be looked at.
Hi All,
Thanks in advance for all your input! View attachment 11808
You might want to double check the length of your safety chains. They look too long to keep the coupler off the ground in case of a disconnect.
Have a great trip.
Those are great points. We will be staying 3-4 weeks. My in-laws place is a bit cramped for all of us to fit, and they have a 2 room cabin up on Lake Superior so the plan is to take the trailer so all the cousins can join and have space. I will look into hotels though and see what that cost looks like.
I did look at plane tickets and a rental car...the car itself for 3-4 weeks was around $3000! I figure we just buy a car there and sell it when we leave haha!
Have a great trip.
Thanks for that observation! It does have to go back to the dealer for some warranty work. I wonder if they can shorten those? Any recommendations on what to do to shorten them?
2021 Ascent Touring, Crystal White Pearl
I’ve driven I-90 through the Cascades and Rockies several times. There aren’t really steep grades that you find on other freeways or highways. With trailer brakes you should be fine in both directions.
Last week was the kids spring break. We did about 1500 miles from Northern California down the coast then over to Joshua Tree then back up towing a Geo Pro G19BH. That included a trip up over the Grapevine coming out of LA. This thing drove as well as it always does. But I did figure out it helps to turn off the lane assist in the mountains and high wind as it tends to overcorrect sometimes.
Hi guys
(First, sorry for my soso Québécois english !)
Stwist the chain, good tip.
I just got a camper trailer 3600lbs and i Will instal anti-swing and Stabilisator bars. That do egal pressure on the car, the front of the véhicule gonna drop the same of the rear. It feel like driving a train, it's verry stable. And of corse, brake control. Dont forget you pull almost the double weight of the car, so in emergency, triky part or suprise of the road, it can push you by the back in verry bad situation !
By the way, I treid it whitout those equipments and il was surprise how good the body of the Ascent work!
Enjoy your trip !
11863
I bought my '21 Touring specifically to be my tow vehicle. I wanted all the benefits of driving my Subaru (also own a Crosstrek) while pulling an R-Pod 196 (3,600 dry / 4,700 loaded). So I have high expectations for our new ride. However, we still have no experience as we are waiting on R-Pod factory delivery.
Question for the forum. Does Subaru expect or require more frequent CVT maintenance when trailering?
I was under the impression that the Ascent models rated for <= 5K trailer weight had special engineering to accommodate the additional demands on the CVT up to the full covered life of the transmission (100K). Am I wrong with wishful thinking?
Yes, you will find this in your Warranty and Maintenance Booklet's maintenance schedule. You should let a skilled Subaru dealerships do a CVT fluid change per the interval.
Subaru does not allow use of a WDH with the Ascent. Please see the stickied thread at the top of this Towing discussion area for specifics. And yes, that "do not use WDH" is in your manual in writing.
Hi All,
That speed and rpm range should be great.
Always turn off lane assist while towing. All it will do is induce sway and fight the sway control, neither of which are what you want! :D
1 - 18 of 18 Posts
