1 - 20 of 37 Posts
Was at the dealer getting my 3 recalls done and asked about lift kits and whether they'd install them. They have the ReadyLift kit for $450 and $750 for install. I was looking at the LP Adventure Kit but it is $850.
Is it worth double the price? Any drawbacks to the ReadyLift kit? Tempted to just go have the dealer do it!
I would normally install this myself but I'm really low on time atm and don't want to wait.
It depends what is included in the lift? The main difference in types of lift are rear subframe spacers. Without the rear spacer, it can be difficult to get within good rear alignment specs.
I am not sure there is much difference if all the lift is ... is just strut spacers. I do not know if there are camber spec differences between the offered lift kits, if they are just strut spacers.
I think you need to find out just what lift packages from each company is being offered. If we all want to get technical. Then get the specs, if possible.
Hello, I have the LP Aventure 2" lift with Bumper Bar and front skidplate. I want to say that the product is very well made and the installers had no problem installing everything. It was cut to fit. After installation they were easily able to do a 4 Wheel Alignment and after 10,000 miles, I have had zero problems, squeeks, etc. I know it is more expensive, but I feel it is of excellent quality.
^^already back up to $399. Still better than $450!
No, you have to look at other sellers! $313 now! On back order, but still. Ordered it at that price! Can still have the dealer install for $750.
It looks like the LP kit adds some different brake line brackets. Other than that they are very similar.
Amazon is tricky that way;
The primary price isn't always the cheapest. Scroll down and you'll see 3 other sellers including Amazon. The Amazon version is free shipping and the cheapest.
To add on to that, I've saved tons of money buying "used" from Amazon Warehouse deals. Basically they are just open box items. It can be 10% off and sometimes closer to 50% off.
Got a Schalge Smart Lock (retail $180) for $130 because the manual was missing.
Got a Roomba (retail $750) for $550 because it had been used once. Turned out a nickel was stuck in the wheel which was why it was returned!
And many many more. I always check that first. Heck if I don't like it as used I can still return it for a full refund and buy retail :D . So far out of at least 200 items I haven't returned any.
Reactions: J_Ascent2020
They are quite different, the LP Kit comes with the rear subframe spacer I mentioned before. The ReadyLift is a simple strut spacer kit. As I mentioned before, kits like this can be a challenge to get the rear alignment correct. There is only one adjustment bolt on the rear and it achieves both toe and camber. Without dropping the rear subframe, the rear suspension angles are maxed out and you don't get much flexibility with the rear alignment. There is a big reason the LP Kit costs more.
Either way, after the lift, you might want to upgrade your sway bar bushings since you will be raising the center of gravity. Oh, and you might also want a CVT mount insert if you develop the "wobbles". Look me up for either.
:devilish:
I am about to order the LP adventure lift kit, and you're saying the dealer will install this upon request? It doesn't mess with the eyesight or warranty? Thanks.
Since when do dealers install after market equipment?
They have been instructed that it's a bad idea, a few months back. So, nowadays, probably not. Eyesight was just one of the reasons Subaru Corporate cited.
Howdy - I'm about to pull the trigger on getting an Ascent and have been reading through these threads on Lifts and the possibility of "wobble" and other CV issues. I want to get a 2'' lift and some A/T tires and new wheels, nothing too big or aggressive, certainly nothing with any rub, but something more than the stock, and go as light as possible on both. The dealership says I can get it all covered by warranty if I buy through them. They subcontract it out to a local company. I have reached out to that company and they only use the Readylift 2'' kit, which this thread suggests is inferior due to lack of the rear subframe spacer.
Questions:
Is it worth it to pass up on the inclusion of the warranty and just do it myself with a better lift kit? The price difference doesn't bother me, if I know I'm getting a better product in the end, especially if it means I'll have a properly aligned vehicle from it.
Should I go straight for the CVT mount insert when I put the lift in? Or wait and see if I actually have an issue?
Any drawback to waiting on the lift kit a while? I see some threads where they say if you want until it has some miles on, putting the lift in then increases the chance of the wobble or other CV issues.
I am upgrading from a Forester, mainly because I'm getting a camper that weights ~3800lbs, should that affect my choices at all? Should I look at upgrading the rear (or all) suspension to handle the extra tow weight? I've had sports cars and I'm beyond that stage in my life where I want the hard suspension/low profile tires beating my back up, so I don't want to go too tight, but I don't want it snagging or being dangerous/difficult to tow.
Thanks ahead of time!
Hello, When I did the 2" LP Lift ,1 year ago, I replaced the CVT and other bushings all at the same time, since it was all apart anyway. I have been very happy with my lift and TrailDogs bushings. I have 17,000 miles on it and no wobbles or any other problems. Rides nice and firm.
Questions:
Only thing I can think of as far as waiting, assuming you’re buying new, is putting extra load on the drive train during the first 1000mi break in period. Beefier tires make the engine work harder...
The suspension is already designed to tow 5000lb so no need to upgrade anything. With the lift installed you’ll just need a longer drop hitch that can keep your load level while towing.
Has anyone purchased a brand of lift outside of LP Adventure or Readylift? I was looking on Ebay and they sell a kit that looks really similar to the others for only $119. Any luck?
1 - 20 of 37 Posts
