1 - 6 of 6 Posts
Hi,
When I stop my car, I hear a single knock noise. Is this expected? I have usually engaged the parking brake and also have it in Park when I turn it off and at that moment when I hit the start/stop, a single knock I can hear.
Can you record it? Sometimes, the Evap System may make a knock sound, but, there's so many other possibilities...
When I stop my car, I hear a single knock noise. Is this expected? I have usually engaged the parking brake and also have it in Park when I turn it off and at that moment when I hit the start/stop, a single knock I can hear. Thanks!
Ours makes an audible "click" or "snick" sound from the engine area 1-2 seconds after the engine turns off. I think this could be:
  • electronic throttle's butterfly resetting itself
  • tumble generator valves in the intake manifold resetting themselves
  • camshaft phasers resetting themselves
  • turbocharger's wastegate resetting itself
There is good number of electronically actuated components under the hood, any one of which could be readjusting or resetting just after shutdown.
And then, inside, is the shift solenoid mechanism.
1 - 6 of 6 Posts
