1 - 2 of 2 Posts
I have somehow turned off the keyless option by holding the handle. It now sounds out a long beep when I try to lock and nothing happens when I grasp the handle to unlock. The remote for the keyless entry is fine. The doors are not ajar... I can't find how to enable this again. Any ideas???? Thanks!!!!!
Sounds like the beeps when one key is in the car. Is the other key in there??
If not, the manual describes how to activate/deactivate keyless entry. It’s a very complicated process that you don’t do by accident, so it’s probably not what you did. But you could try it to reactivate. Note that according to the manual turning off keyless entry by the door method can only be reactivated by the same door method, and turning off keyless entry with the keys can only be reactivated by the keys; there’s no crossover.
1 - 2 of 2 Posts
