1 - 11 of 11 Posts
Let me start by saying that I know I should be holding the steering wheel at all times with both hands just above 3 o'clock and 9 o'clock. I know this yet I am human and on occasion do otherwise. I have, in a safe location and with my hands hovering near the steering wheel, tried to play with the car's AI a bit and let it try to keep me in my lane without touching the wheel. After a short time of this the center console lights up with a notice to keep my hands on the wheel. I have had this message appear when I HAVE had one or both hands on the wheel, just below 3 and 9 o'clock. I also imagine this information is being saved in the car's activity log in case of accident.
The message goes away, I think, as soon as I touch the wheel or turn the wheel. Does anyone know exactly how the car senses my hands are not on the steering wheel? :dunno: Is it an electronic current thing or maybe the action of turning the wheel? I am very curious about this and I promise I am doing better about keeping my hands properly placed on the wheel! :grin:
This has happened to me too on occasion—with my hands in the wheel—on road trips with a straight stretch of road, where I kept my hands perfectly still. I think it senses if you’ve moved the steering wheel in a certain period of time. I was able to have the message go away by just gently and very very slightly moving the steering wheel.
I've had this problem on both my Ascent and my S4. Drive too long on a perfectly straight road and the system complains you aren't holding the wheel, even if you are. The Audi system is far more annoying about this however.
Thanks Luis, that seems to say that the detection is actually turning the steering wheel. I will say it is very very sensitive to that action. It has turned off the warning when I thought I hadn't turned the wheel at all, just gripped it tighter or moved my hands.
No problem,there’s alot of material to read about this Eyesight system.I just picked a page that was close to what you were experiencing.I’ve owned my Ascent since November ‘18 and I’m still find myself skimming through the manuals,easier when it’s on a smart phone.
The only way I've had it activate is when you let it ping pong side to side 3 times. As in you let it correct for you 3 times in a short span and it will yell at you. I have not had it happen on long straight stretches but our roads aren't smooth enough to require no input.
Yes, happens to me all the time. No steering input and it'll yell at you, even though you don't NEED to move the steering wheel!
2019 Ascent Premium
The message goes away, I think, as soon as I touch the wheel or turn the wheel. Does anyone know exactly how the car senses my hands are not on the steering wheel? :dunno: Is it an electronic current thing or maybe the action of turning the wheel? I am very curious about this and I promise I am doing better about keeping my hands properly placed on the wheel! :grin:[/QUOTE
I've never encountered this, regardless of how many hands I have on the steering wheel, and regardless of what position they are in - very strange. Having said that, I don't drive without at least one hand on the steering wheel, so maybe the act of driving without any hands on the steering wheel initiates a separate set of warning parameters.
Put it on an arm lift or jackstands and run it at 40 stationary and see if it yells at ya :)
From all the testing I've done it triggers one of 2 ways.
Too many "Lane Departure" warnings in x minutes.
NO steering input for Y seconds.
So if you let go and let it "do it's thang" and pinball back and forth between the lines it'll yell at you.
Or if you are on a straight flat smooth road (like rural AZ) and have one hand lightly on the wheel but don't have to turn it at ALL, it'll yell at me. A slight turn of the wheel and it goes away.
1 - 11 of 11 Posts
