1 - 19 of 19 Posts
I experienced an issue with my vehicle this weekend that occurred twice. The vehicle was off and started making a high-pitched noise (either like a fan or a small motor) from the rear driver's side of the vehicle. The only way I could stop it was to turn the vehicle on and then off. My concern is it could happen without me knowing and drain the battery.
I don't know what triggered the first occurrence but the second time happened after I walked by the vehicle with the key fob triggering the interior lights to turn on but I never opened the vehicle. The interior lights turned off after some time and then it started making the noise. The first time it happened I thought it might be the rear lift gate motor but I was able to open and close the rear gate while the noise continued.
I am scheduled to bring in to the dealer Wednesday but I was a little concerned that they are already preparing me to take a loaner. Hopefully this can be addressed quickly.
Here is a recording of the noise taken last night in my garage so there is really nothing to see.
quite loud for a fuel pump. Isn't that where the rear AC unit is? Maybe a fan for that?
i know on page 9 of the owners manual it says this:
You may hear a noise from under the vehicle approximately 5 to 10 hours
after the ignition switch is turned to the “LOCK”/“OFF” position. However, this
does not indicate a malfunction. This noise is caused by the operation of the
fuel evaporation leakage checking system and the operation is normal. The
noise will stop after approximately 15 minutes.
I am not able to watch the video at work. If it only happens when it is OFF, then this is likely a solution.
Interesting find. I haven't let it run that long so maybe that is the case. If I encounter it again I'll let it run that long to see what happens.
This is what it probably is. I have a 2018 Outback and it was making the same noise. I asked the dealer if it was the fuel pump, and they told me it was the fuel evaporative system. I heard it the first few months I had it, but have not heard it for a while now.
It is this! My last 2 Subarus have done this (2014 Impreza and 2017 Outback). If you're worried and hear it again, set a timer for 15 mins and go check again when the timer goes off.
Yes, freaked me out the first time I heard it too.
Mine is in the shop now. There was a loud noise in the rear on the driver's side that sounded like a bad fan. It happened when I turned on the ventilated seat fan on the driver side.
The shop said this had been reported before and they want a regional technician to look at it. I'm in a base Forester loaner. It's nice but not my Ascent.
As with many electrical problems, it is intermittent. At least the dealer heard it twice before ordering a new fan.
So glad I was able to read this a couple of months before I picked up my Ascent. I would have feared awaking to a dead battery in the morning.
https://youtu.be/3OrfH6k52ak
I had been hearing a motor running for quite some time and thought it was my new garage door opener. Today I heard the motor distinctly coming from the rear of the car around the tow hitch. I called the dealer and was told that it is a fan to remove pressure from the gas line. He said it was perfectly normal. In a way I was disappointed b/c I thought I had discovered the reason my battery dies alot.
Next time that happens, please do the following if you can:
  1. Record it.
  2. Open your liftgate and let me know if the sound stops.
Thanks for the info on this everyone. I noticed this a few times recently when organizing our new garage. It is definitely quite loud for a car to start doing this randomly when you don’t expect it. Based off the information presented from the owners manual, I’m not going to worry about it.
Yeah, it's an odd sound to hear. So is the occasional clunk it makes.
I have a 2020 Forester and just noticed this noise. I'm living in NE Wisconsin and because of the weather lately (5 to -10), I (a smoker) have been going out in the garage to partake. I get home from work at 10:15pm and the last 2 nights, I've noticed this sound around 3-4 am. The first night I am pretty sure I didn't notice it before then. I thought I corrected it by opening and closing the back gate. Tonight (the 2nd night) I just noticed it and turned the ignition to on and it went away. I googled and found this thread. I'm grateful for you guys helping me understand what it was. The first night I was literally unplugging the garage door, walking around the car, bringing out my phone and recording, all the things that people here were doing. Thanks again for this thread.
I happened to be right under mine when it did it once. It was scary as hell, when you're under the car, and suddenly it makes a big clunk, and you're waiting for a jack stand and floor jack to collapse, thinking it's one of them that's shifted and made the clunk. It was followed by the odd pump/vibration sound it makes, and I put two and two together. But, when you're under a car and you hear a loud sound like that from right near one of your jacks... 🤣😞😉
1 - 19 of 19 Posts
