No. I changed my oil at 3200 miles and it was still completely full. Of course, one anecdote is fairly meaningless. Good luck.
I wouldn’t count on anything being the same as the initial break-in and oil fill. You won’t really know until you get a full change or two in.2200 miles on my Touring, checked the dipstick and I'm down about 1/4" below full. Something to watch
Every Toyota I have owned used about 1 quart every 2000 miles. But my current 4.7L v8 will go through 3 quarts in 4000 miles if I use Mobil 1 synthetic, same for my 1.8t VW but using a higher quality oil results in around 1 quart every 4000-5000 miles.Fair question based on historical fact. Keep in mind that Subaru wasn't the only manufacturer to experience the oil consumption issue - Toyota had the same problem and issued a TSB that extended engine warranties up to 150k miles. There was another manufacturer but don't recall which one. So if not a new subie, toyotas need extra consideration.
You must be in Europe or have a special US source for the Euro blend which was replaced with a very low quality base oil in the US retail market around 2008 ish when the US spec Mobil 1 started being associated to oil use in cars that hadn’t before the switch to a higher volatility lower quality oil.I don’t know about anyone else but I have been using 0w-20 mobile 1 full synthetic for over 12 years on my cars. Never any burning issue or consumption of any sort. Unless you change the oil yourself, it’s time for you to change mechanics. As far as this new engine is concerned I don’t believe there will be any burning oil problems. Have any of you looked at the Intercooler at all? I’ve always been a Honda guy so I’m not used to Subaru’s design just yet but I’m getting there. The intercooler on this engine, unlike all the other models, only has 2 connections. It’s only connected to the throttle body and the turbo. That’s it and nothing else. I saw this when I was working on the car. View attachment 5039
All engines consume oil. It's how much they consume that determines whether it's an issue or not. :tango_face_wink:In general, I wouldn't worry about oil consumption with Ascent. Engine is FA24dit and it is not related to FB20 and FB25 that had oil consumption issues (and more on manual models). It is engine completely based on FA20dit that is powering Forester XT and WRX for 5+ years. No major issues expect sporadic pre-ignition/hard start issues on early models that was supposed to be resolved with recall. I follow subaruforester forum and that engine seams to be rock solid.
One thing that would make me monitor situation is that on Ascent they switched to 0w-20 oil (that is thiner and better for fuel economy) from 5w-30. It is the same oil grade as FB engines and many people think that ultra thin oil on new engines is to be (partially) blamed for oil consumption.
You points are valid but FB definitely had oil consumption issues, especially early models (2011+) and again with early SJ Forester (2014-2015). There is a lot of info about that on Subaru Forester forum. I think that Subaru was hit with class action lawsuit about that and that certain model years had extended warranty and short blocks replaced quite often. General consensus was that manual models were more often affected and that CVTs and later models were less affected. Some members were using thicker oil and they reported improvement. I don’t have enough technical knowledge to go into detail about differences but it seams that FA engines of any years had none of those issues and it was never addressed by Subaru.The FA series engine IS based off the FB series, which did NOT have that problem to my knowledge.
I believe you are referring to the oil control rings which had a manufacturing defect from the supplier. This was corrected.You points are valid but FB definitely had oil consumption issues, especially early models (2011+) and again with early SJ Forester (2014-2015). There is a lot of info about that on Subaru Forester forum. I think that Subaru was hit with class action lawsuit about that and that certain model years had extended warranty and short blocks replaced quite often. General consensus was that manual models were more often affected and that CVTs and later models were less affected. Some members were using thicker oil and they reported improvement. I don’t have enough technical knowledge to go into detail about differences but it seams that FA engines of any years had none of those issues and it was never addressed by Subaru.The FA series engine IS based off the FB series, which did NOT have that problem to my knowledge.
