I recently found out that the installation instructions for accessories are available for free. The shop manuals - probably not.I don’t think STIS is free?
Accessories instructions are free on STIS. You can perform any search you want, and it will return all results but only allow you to access some of it (such as accessory installation instructions).I don’t think STIS is free?
Can you define/quantify “easy”? Just posted about this asking for a number between $0 (DIY theoretical cost) and $400 (dealer labor cost) for the DIY install. How long did it take you? Did you have issues with some clips/some other small part breaking and needing to buy extras of that part to get everything secured?Easy install though
here is a instruction video for the 004 versionI don’t think STIS is free?
Hard to quantify other than the time it took me personally, which was about 3 hours. It could’ve been done quicker but no reason to rush it. I did pay a little to buy a torque wrench and socket set at the time, which seemed a better investment than paying dealer labor hours.Can you define/quantify “easy”? Just posted about this asking for a number between $0 (DIY theoretical cost) and $400 (dealer labor cost) for the DIY install. How long did it take you? Did you have issues with some clips/some other small part breaking and needing to buy extras of that part to get everything secured?
As with all things, it depends on what your time is worth. Could i have done it myself? Probably. Was it worth what my personal $/hr cost is for the 4-ish hours I suspect it would have taken me? Absolutely not.Can you define/quantify “easy”? Just posted about this asking for a number between $0 (DIY theoretical cost) and $400 (dealer labor cost) for the DIY install. How long did it take you? Did you have issues with some clips/some other small part breaking and needing to buy extras of that part to get everything secured?
i have camera in garage .. i pull timestamps to see how long it took ..As with all things, it depends on what your time is worth. Could i have done it myself? Probably. Was it worth what my personal $/hr cost is for the 4-ish hours I suspect it would have taken me? Absolutely not.
Here's where the new ground wire is supposed to go:I just bought the L101SXC005 kit from my dealer to install on my 2022 Ascent. It includes the H771SXC002 wiring harness (with a sticker on it that says "New Ground Design". It has a ground wire coming out of the side of the harness that plugs into the car-side plug with a ground ring on it. Also, there is a single screw (p/N 904580002) that is included in the kit (looks like it fits in the ground ring). Anyone have any idea of how this is supposed to be installed or have a link to the instructions for this version?
this came up as 'sensitive content, not recommended for those under 18'
I saw that. I have no idea why that happened. It's just a screenshot from my Mac and that's now the file is named as well. Weird.this came up as 'sensitive content, not recommended for those under 18'
i'm fine with leaving it that way![]()
Thank you! One follow-up, is the only plug inside the cargo area a 4-pin and I need to buy a separate 4 to 7 pin conversion?the bottom of the cargo area is where you plug the harness that goes to the hitch in.
the oem hitch itself does come with separate 4 pin and 7 pin connection points, one on each side of the hitch
your brake controller assumption is correct. there are many threads on the subject so that's a good place to start or ask any other questions that haven't been answered already.
its somehow marked nsfw... I can fix it if you want, its just more fun this wayI saw that. I have no idea why that happened. It's just a screenshot from my Mac and that's now the file is named as well. Weird.
No, you do not need to buy anything like that.Thank you! One follow-up, is the only plug inside the cargo area a 4-pin and I need to buy a separate 4 to 7 pin conversion?
