1 - 8 of 8 Posts
I got this idea after doing the install on my tundra.
Added two led waterproof lighting strip on each side of the hood to illuminate the engine bay. I found that I hated trying to find a flashlight when checking the oil dip stick or refilling fluid in the garage or in the dark.
There's a hood pin that completes the circuit when it's opened. Otherwise it's off when closed.
3346
3347
3348
3349
Looks good. I was thinking of doing something like that. What gear did you use? I was thinking of something similar to this truckbed lighting setup.
Here's my truck setup
3363
3364
Stuff I bought are
1. wiring
2. hood pin
3. led
don't forget to use a fuse holder and wire loom to conceal and make it look pretty.
That switch connects the terminal to its body when it's closed (hood open). The body of the switch is grounded to the metal where it's mounted. So +12V to the lights, lights to the switch terminal, terminal to ground when the hood is opened.
Very nice! How do you wire to that switch? I only see one terminal. :unsure:
See blow.. :) Yes
Thanks for responding.. I've been busy with other things so I haven't had a chance to come in but that is correct. the terminal is grounded, when pushed down it loses contact when it pushes up it completes the circuit thus the magic.
1 - 8 of 8 Posts
