Hi all, I'm thinking of doing the same project. Installing a DC-DC charger in a near future for a LifePo4 battery upgrade on my camper. Initially I thought maybe to make life simple, just locate and pull the fuse for the 12v 7pin and just let the (to be installed in the future) solar panel charge the battery. However, for long term, I think a DC-DC charger will work better charging. One single 175 watt panel might not be enough to top off the Lifepo4. The reason I'm thinking of upgrading to a Lifepo4, possibly a 300ah single battery, is because I have a 12v DC only 4.5 cubic foot refrigerator. It draws 6amps when running.
Anyway, I read on this form that there are several ways to run this two +- wires. Some ran it under the car behind the shield and panels and some ran it inside the car. I'm not car expert. My knowledge of wire run in cars was installing a few backup cameras for my older cars to the license plate. All the cable tucked under rubber seals and maybe popped one or two side panels
I checked Robert's video. The run is inside the car on the driver side. It seems to be a good run but look difficult to pull all the panels. Underneath the car means I have to crawl under the car. The wires might be exposed to road salt and other stuff that can damage the wire. For an amateur, what is my best option?
Also, what kind of fuse and/or breakers do I need for this run? Any Amazon links? I'm trying to better understand what I need to do before buying all the parts.
Thanks so much.
Thanks so much.
