Just got a new Ascent Limited and while all the USB-A ports are nice they are so 2014. Does anyone know a way to get Google Pixel fast charging, which is via USB-C and the "Power Delivery" standard. I think the Pixel draws basically <= 15 watts?
You will have to use a quick charge car adapter that plugs into your 12V Cigar Socket and then connect your USB-C cable to that. Yes, unfortunately that means you won't be able to hook up your phone to the ports that utilize Android Auto. Here are some car adapters that should work with fast charge.Just got a new Ascent Limited and while all the USB-A ports are nice they are so 2014. Does anyone know a way to get Google Pixel fast charging, which is via USB-C and the "Power Delivery" standard. I think the Pixel draws basically <= 15 watts?
