Any thoughts about the horn sound on the Acent? Every time when I press the horn, it sounded like just behind the dash board. For a car cost as much as 35k, should have a better insulation. Any one agree with me?
Yes I notice and it is kinda strange to me. I wasn't able to see horn thru the bumper grille and I didn't try hard to find it either. Also, it appears that Robert is saying that the horn is out of sight and hard to get to. Therefore, the issue might be that the sound deflect/bounce all over the engine compartment instead of projecting straight out.Any thoughts about the horn sound on the Acent? Every time when I press the horn, it sounded like just behind the dash board. For a car cost as much as 35k, should have a better insulation. Any one agree with me?
is the horn(s) under the headlight(s)?All of us who've discussed the horns want louder ones. You can use the search tool to find the thread, if you are interested.
I bought a pair of Hella horns, but, the horns are mounted as far away from human occupants as possible, under the bumper cover, in front of the bumper, so, it's not a swap I want to do in this weather.
Regardless, personally, I find the soundproofing in the Ascent to be fine, and definitely light years ahead of what my 2010 Outback had.
Anyway, my first car was a 63 Chevy, so, I look forward to loud horns for the few times I use them.
Yes, thanks. I suspect it's bouncing off the bumper cover and reflecting back inwards.Yes I notice and it is kinda strange to me. I wasn't able to see horn thru the bumper grille and I didn't try hard to find it either. Also, it appears that Robert is saying that the horn is out of sight and hard to get to. Therefore, the issue might be that the sound deflect/bounce all over the engine compartment instead of projecting straight out.
Also, my kid honked the horn while my head was under the hood - scare the bajeebus out of me.
Yes. Kinda. See the image below. I have a feeling, with all of the stuff for cooling and everything that kicks in through the grille, they wanted the horns out of the way.is the horn(s) under the headlight(s)?
Added Hella horns just this evening. Took the plastic off above the radiator to access behind the grill and mounted them under the hood latch. Tapped the driver side horn found under the headlight to power a relay that switches battery to the new horns. Relay switches battery through a 15 amp fuse to the new horns. Now both factory and aftermarket horns are in play. I have a sound meter. Stock horns measure 109dba and both sets together output 117dba. Boy are they LOUD!!!!!
I have the yellow/blue Hellas, not the red/black ones. I like the lower frequency of the yellow ones. More 'truck' like.
I'm hard of hearing and they were so loud during testing, I could tell they were gonna damage what I have left, so further testing was done with my shooting ear muffs. Ha!I haven't heard the hella horns in person, but I've never been impressed after watching various YT videos. I guess they must sound way better in person
