1 - 15 of 15 Posts
Like it says in the title - where does your hitch hang out when not in use?
In my OB, I had a space for it beneath the trunk floor that was foam, above the spare tire. I believe this was split into two sections - either way, I kept the hitch in there, along with jumpers, gloves, tire chains, and other things I needed to carry but would infrequently use.
I did try to use the storage beneath the trunk floorboard in the Ascent, but given the width, it was sliding around quite a bit.
If I'm carrying it in the Ascent, I carry it under the cargo area floor in the storage area.
My ball mount and locking pin go in the cargo storage bin under the floor in the back, wrapped in a dish towel so they don't make noise.
I keep the locking pin installed in the receiver. My ball mount is in the shed since it’s rather heavy and also don’t tend to do spur of the moment trailering. Underneath the trunk floor I do keep my ball mount that came with the hitch (back when that was a thing) with a shackle attached and a tow strap, just in case. Knock on wood... my jumper cables help it not slide around but I haven’t needed them, yet.
I keep the factory hitch and pin in the box, in the rear storage. Never hear it rattle or slide around. Also been told I drive like an old granny. In reality, I'm just saving it.
I've got a decent Mendocino pin stripe job from manzanitas, and half mile hilly dirt driveway. (and I leave a full carlength ahead of me when driving 70 on the freeway)
I made a foam cutout to hold the factory hitch that is form fitted to the left side of the under floor storage. I added a layer of shelf liner foam to the bottom to keep it in place (because I drive like I think I'm Senna). I've since changed to an after market hitch (less drop) and haven't gotten around to taking pictures of it but it's the same idea.
4968
4969
4970
The Subaru mount was too big and heavy and it's somewhere languishing in the garage.
The drop mount for our camper is in the garage next to the sway control bar.
The replacement 2" mount that I use for our small utility trailer is in the back under floor compartment, jammed from moving with lots of other stuff like rope, jumper cables, tools, toilet paper, the manual, etc.
1 - 15 of 15 Posts
