If you don't get an answer by then, I will try to get you one early April. Only problem is, I've yet to see one where the hitch is clearly visible at car show. Always covered by the cover. :crying:So here's a burning question for me and my elaborate bike rack to anyone going to a auto show with a tape measure.... what is the distance from the ground to the bottom of the receiver opening?
Does the one on your Outback go under the bumper? because the one on the Ascent will have a cutout in the bumper. My parents have that same issue on their Odyssey because it is aftermarket.Well, I scrape my hitch without a rack, add to it a Yakima HoldUp2 and Kuat Pivot onto your 2012 Outback and you've got troubles. I left a gouge in the street in front of my house yesterday. Good times. I'm estimating the Ascent hitch to be about 11 inches and the better towing specs should clear that all up.
I think it will be more than that for the Ascent (bigger wheels/tires). I have a 2" receiver hitch on my 2018 Crosstrek, and center of the receiver is 14" from the ground, or 12.5" clearance from the bottom of the hitch. This is a Curt "hidden" hitch, with the crossbar up behind the bumper. Can only see the receiver portion from behind.Well, I scrape my hitch without a rack, add to it a Yakima HoldUp2 and Kuat Pivot onto your 2012 Outback and you've got troubles. I left a gouge in the street in front of my house yesterday. Good times. I'm estimating the Ascent hitch to be about 11 inches and the better towing specs should clear that all up.
This might help you, too.Yeah, that would be great. Thanks for the input. The Kuat Pivot hangs down maybe an inch or two below the receiver and then the giant bolt it pivots on hangs lower than that. I would love for that to not be an issue.
My 10 OB is way done on the rear springs. The Ascent delayed my RalliTEK new struts plan for it. But no Bench 2nd row Touring and recent discovery of my wifes HOV sticker ending in 2019 has further delayed the OB replacement/upgrade plan.I guess it was about 130 pounds hanging off the back (pretty far). Not sure why it was sagging so low though.
Yeah, it's normally 10% of towing weight.OB forum member was just told by a sales rep 500lb Tongue max weight for the Ascent.
