How big? Do you mean a whole GPS/Nav system? If so, look at the full Eyesight manual, and it will show the safe area.I'm supposed to pick up our new Ascent tomorrow.
After reading the Eyesight Quick Guide I'm wondering where others wound up putting their aftermarket GPS system.
I would mount it like a regular phone, with a proclip (or similar product) on the front of the dash. That way it won't interfere with the safety systems.The manual isn't real clear about the "safe" areas - are the "B" zones safe?
I also have this GPS which I have successfully mounted onto the vent on the right side of the head unit in my Ascent.No it's a stand-alone Garmin 65LMT (6" diagonal screen) currently sitting on the dash of my Accord
No sure about the Ascent but in my Legacy I've mounted one as low as it would go on the center it basically is on the dash in the middle and eyesight still worked perfectly. I've place my parking pass for work right above the steering wheel before and the reflection from it caused eyesight to turn off.
Sparkland - Thanks for the info.
I "re-looked" at the Eyesight Quick Start and Zone "C" (on left side of dash near the windshield pillar) appears to be the only place I can place it and not interfere with Eyesight.
What additional info do you have on the Garmin Ascent mount?
Thanks
Android Auto / Apple Carplay both put your GPS on your infotainment system. Thats a 6.5" screen in the base model, or 8" in any of the higher models. Both bigger than your existing Garmin.I've been using Garmins for 15+ years and switching to maps on my phone (smaller screen than my Garmin) would be like trying to drive with the steering wheel on the right side of the car.
Sometimes I just want a map on the screen without going anywhere in particular. Seems hard to do, I need to run the map app and it's a pain.Android Auto / Apple Carplay both put your GPS on your infotainment system. Thats a 6.5" screen in the base model, or 8" in any of the higher models. Both bigger than your existing Garmin.
Give it a shot. You'll never go back.![]()
Not in the least bit. Start up AA/AC.. click on the maps button. Thats it. No need to put in a destination.Sometimes I just want a map on the screen without going anywhere in particular. Seems hard to do, I need to run the map app and it's a pain.
Google Maps on Android has driving mode, which is essentially a Navi with no destination. You can create a widget for it as a shortcut, shows you traffic too.Sometimes I just want a map on the screen without going anywhere in particular. Seems hard to do, I need to run the map app and it's a pain.Android Auto / Apple Carplay both put your GPS on your infotainment system. Thats a 6.5" screen in the base model, or 8" in any of the higher models. Both bigger than your existing Garmin.
Give it a shot. You'll never go back. /forum/images/smilies/smile.gif
Thats only when running it on a phone though, which he doesn't want to do because of the smaller screen.Google Maps on Android has driving mode, which is essentially a Navi with no destination. You can create a widget for it as a shortcut, shows you traffic too.
Yes, AA uses Google Maps driving mode, just giving notoptions.Thats only when running it on a phone though, which he doesn't want to do because of the smaller screen.Google Maps on Android has driving mode, which is essentially a Navi with no destination. You can create a widget for it as a shortcut, shows you traffic too.
AA has that built-in natively. I'm not sure about Carplay.
