Thought I would take the opportunity to inform anyone that if you blow a fuse while switching the interior lighting to LEDs, the fuse to switch is #26 on the interior fuse panel. It is not clearly labeled on the cover. This is also the fuse for the key fob functions and homelink. Hope this helps if someone makes the same mistake as me...using a screwdriver to pop out the hot bulb and touching the metal socket for the bulb.
