1 - 3 of 3 Posts
My exterior "Welcome Lighting" lights do not come on. I did replace my headlight bulbs and reverse lights but I don't believe this should cause an issue.
I did check my setting to make sure they were correct ? Any ideas ?? Thanks.
Check your settings via the infotainment system. And are you talking about the headlights or lights under the side view mirrors?
Thanks. I figured it out. My light switch has to be set on Auto. Not sure why but thats what did the trick. And it was the headlights and the brake lights. I have the premium so it is not equipped with the flood lights under the side mirrors unfortunately.
1 - 3 of 3 Posts
