1 - 4 of 4 Posts
Tried search thread, but didn’t find anything. Is it possible when using turn signal, we can leave the DRL on? I see previous Forster model DRL stays on with operation of turn signal.
While I'm afraid I don't have the knowledge to be able to help you with your current question, I would simply like to point out that this is actually a safety feature.
One of the longstanding complaints that detractors had of DRLs is that it can impair visibility of the turn-signal, particularly if it the turn signal is situated close to the DRL module.
This is why in previous years, you'll only see high-end vehicles with same-side DRLs that deactivate or dim when that side's turn-signal is activated.
I've been saying we need a switchback c light , being that it turns off the main drl for signals and that the factory turn signal does not have a true switchback feature.
Also it would be nice if they did something for the lower fog light bezel as well
1 - 4 of 4 Posts
