Clearmask seems to be the least expensive..... I’ve used them many times..... order soon, they’re going to discontinue free shipping on orders over $75. I’ve used the 3M film. For first timers applying film - a couple of tips.... A table top near the vehicle helps a lot, spray everything with slip solution (baby shampoo works best) frequently, including pieces, surfaces,hands and fingers, use microfiber cloth (included in kits) to super clean surfaces)Can anyone recommend a DIY precut clear bra for the hood? Possibly other areas as well.
Yeah, heat definitely helps to tack down film in contours and valleys I just got a kit to put on a new outback. This will be the 6th family vehicle I’ve wrapped. I’m adding Nano ceramic window application on front windows for further UV protection. The windows are easy flat surfaces, doing the bumper and headlights requires a lot of patience for first timers. The trick is lots of slip solution on everything including hands and fingers.I did mine outside and dust/dirt was an issue. When I did the hood section it was windy and made things difficult. Also used heat when I needed areas to tack up.
