1 - 7 of 7 Posts
The larger vehicles like the Ascent especially the new ones with lots of parasitic power draws. I wouldn’t even bother. If you have a need for a fridge or some other powered device I would just build a power box that gets strapped down in the back and maybe a 12v socket feed from the rear socket to a charge controller to top up the box when your driving.
My Toyota Sequoia has needed me to jump it many times after as little as 20-25 minutes sitting with the key left on powering who knows what systems killing a prefectly good battery pretty fast. The Ascent and it’s light weight battery, shish no way.
Discussion Starter · #4 · (Edited)
I checked today there is no specific relay for the power outlets
I wanted to power my rear dimmable LED strip anytime, say if I was car camping or had the rear hatch open for longer than 30mins. Looks like I’ll just tap into the cargo light power.
If I were to run any wires I’d just go big (2GA and branch it out in the back with a Bluesea 6 circuit) but won’t be running a fridge after all.
I bought a CTEK DS250 smart charger for the Subaru and was planning on sticking a lithium 50ah house battery in the storage area and a flexible solar panel on the roof but just don’t drive it often enough to justify having a 12v fridge running 24/7.
That’s another reason going to the portable power box with solar or 12v socket power as a charge source. Easy to pop out and use at home or other car etc with no complicated hack jobs on the car.
1 - 7 of 7 Posts
