1 - 3 of 3 Posts
Is there a comprehensive list of the pre-delivery inspection dealers should perform along with the service they should perform on the Ascent prior to the actual handover?
I have seen tidbits here and there including:
  1. adjusting the tire pressure,
  2. installing the sill plugs,
  3. assuring the battery terminals are coated,
  4. changing the position of a fuse from shipping to service.
Here you go. It's under "What to Check when taking possession" https://www.ascentforums.com/forum/...check-when-taking-possession-your-ascent.html
1. Done
2. What is this?
3. You mean with goopy stuff?
4. Where and how do you do this?
Thank you.
1 - 3 of 3 Posts
