1 - 15 of 15 Posts
Hi All-
Since I've gone pretty far in terms of aftermarket add-ons and upgrades, seemingly unhindered by taste or the risk of ruining the family car, I thought I'd start a running list, upon which I can expand as there is interest and I have time...
Power Train
-K&N Air Filter
-Cobb Tuning Stage 1 87
-CKE Transmission Mount Insert
Suspension/Steering:
-LP 2" Lift Kit
-Nameless Strut Tower Brace
-CKE 85a bushings
-Method Racing MR 502 18x8 Wheels
Interior:
-Amber LED Interior Light Swap
-Cupholder Hero Liners
-Fuse Box Coin Container
Exterior:
-Broadfeet Bullbar, Running Boards, & Rear Bumper Guard - Removed (Raptor Linered)
-Rhino Rack Pioneer SX Platform
-LED Headlights, Blinkers, and Brake Lights
-PIAA Superior Bass Horns
-DIY ABS Plastic Mesh Grille
-AscentScreen lower grille from @Scarlett
-Yellow vinyl front and red rear light treatments
-Various Plasti-Dip black bits.
I've got a few more fun projects incoming, so stay tuned...
Best,
Christian
3664
Hi All-
Power Train
-K&N Air Filter
-LP 2" Lift Kit
-CKE 85a bushings
Interior:
Exterior:
-Broadfeet Bullbar, Running Boards, & Rear Bumper Guard (Raptor Linered)
Best,
Christian
Looks great. What are those two additional rails on top on the drivers side that rise above the platform?
Hi All-
Power Train
-K&N Air Filter
-LP 2" Lift Kit
-CKE 85a bushings
Interior:
Exterior:
Best,
Christian
sorry double post. Looks great. What are those two additional rails on top on the drivers side that rise above the platform?
The Rhino Rack Pioneer system is all modular: the rails on the driver side could be set on both edges, but when I run a box on the two perpendicular rail things* on the passenger side, I slide them over, to be used as follows if the box isn't enough:
3628
They also make it very easy to strap down lumber.
*One downside of the flat platform is that boxes meant to go around the cross bar don't always work as intended...
Hi All-
Power Train
-K&N Air Filter
-LP 2" Lift Kit
-CKE 85a bushings
Interior:
Exterior:
Best,
Christian
Can the platform be fitted with locks along with the rails?
Does Rhino have an accessory attachment for skis?
I like the flexibility the flat platform provides for transporting sheet goods or lumber as well as containers of all sizes.
Is it quite, with and without the air deflector?
If I ran it without the deflector it was a day or two and don't remember. With the boxes and straps there's some extra noise, but I have 3 kids in the car to take care of that.
Just saw the other questions:
-Because of the way it bolts together, a thief would need the right wrenches and hours to get the thing off the rails. The box has locks.
-Skis, bikes, anything Thule or Yakima makes, plus the Thule or Yakima stuff can fit right in here. Check out their website, tons of accessories from jacks and shovels to led bars, load rollers, etc...
The one downside vs the Prinsu which came out right after I placed my order, is total stack height. At some point, I would like to figure out the correct rhino feet for the platform and take the OEM factory rails off entirely- much cleaner solution.
Discussion Starter · #12 ·
I wonder what the noise level would be if you strap the kids to the rack as well.
That was actually the original reason behind the Brat's name and exterior seating:
3630
I'm a fun enough dad that strapping the carts to the platform and driving the kiddos around doesn't seem so out of the question... With helmets?
Even in your yard at slow speed, that would carry some serious risk. Off your property, a fine, maybe worse and a visit from CPS...
1 - 15 of 15 Posts
