1 - 9 of 9 Posts
The adaptive cruise control gives an annoying alert every time it locks onto a car, loses a car, or locks onto a new car. Is there any way to turn off or turn down that alert? It makes me not want to use ACC at all.
Haha. My fianc茅e hates that, but I like it. I just have the beep volume down low via the menu button on the bottom left of the steering wheel
Check the Eyesight Manual in the attached post...
You can turn it off, or change the volume, all through the settings. This is outlined in the Eyesight manuals, which you can find at the bottom of this post:
https://www.ascentforums.com/forum/...lane-keep-assist-adaptive-cruise-control.html
Regardless, I find the chimes indispensable so that I know it's found a new car and that I won't go barreling into it thinking the car sees the vehicle in front of me.
Yup. I had the chimes on my Outback. The ones on the Ascent are quieter and don鈥檛 bother me at all. I like that it tells me when it sees the car in front and when it doesn鈥檛. That greatly helps to improve driver involvement when using ACC.
Old thread but by changing the volume on eye sight does it change it for all other features as well lane departure etc?
I turned the eyesight beep off completely but the lane thing still beeps, if that鈥檚 what you are asking. I have that low volume but it鈥檚 probably next to go since the little lights at the bottom of the dash are sufficient for me.
Yes, there is 1 volume control setting for all Eyesight beeps under Change Settings in the Combination Meter at the the center of the instrument cluster.
You can only disable the ACC Lead Vehicle Acquisition beep.
civdiv99 - You can't disable the Lane Departure Warning beep.
1 - 9 of 9 Posts
