1 - 3 of 3 Posts
This is more of an FYI rather than asking for a resolution.
This has to do with the Control Switch on the lower left of the steering wheel stalk.
This just started happening. Initially, I couldn't get into one sub-menu, the rest worked fine.
Now, I just get into a sub-menu as soon as I activate the center i/SET toggle.
I'll probably bring it in to the dealer when I have time to have them look at it. I suspect something is corrupted in that part of the firmware. Most likely disconnecting the battery will reset things to normal, but I don't really want to do that because I would rather have this issue reported by the dealership for a more permanent fix.
Has anybody else had this issue?
Thanks
Car needs to be in park, otherwise the menus function differently, and there's less options in the menus.
1 - 3 of 3 Posts
