Some tips:
A few tips:
Hope that helps.
A few tips:
- Make sure you're on the most recent update for the head unit. The firmware number should start with Rel_U1_18 or higher (eg, for Nav units, it should be at least Rel_U1.18.38.50).
- Don't plug your phone in until the head unit boots.
- You can use the button on the left side of the steering wheel (above the hang up button) to activate Google or Siri - no need to use the Wake Word.
- Volumes for everything can be adjusted in Settings->Sound. If it does not maintain those levels (other than you changing them), then, make sure you've updated.
- You can set one station preset (I use the first one) to SiriusXM station 0, which is your Radio ID "channel" and doesn't have audio.
- I use a very fast USB3.0 media stick, formatted NTFS, in one of the USB slots, and usually have auto-play on - the head unit switches to it near instantly.
Hope that helps.
