Were the head rests pulled up?So I decided to climb into the 3rd row to see how it felt. Kinda cramped for an average side adult. It feels like you are leaning toward too.
Luckily, it will only be small children riding back there for the most part.
The rear seat should be able to recline a bit from what I remember
They force you forward in an uncomfortable position if they are not pulled up at head height.
The seats can be reclined back a bit more using the short strap on the right and left side.
LOL it took me a few days before I realized I should probably try sitting in the 2nd and the 3rd row. The 2nd row bench seats were pretty spacious but I realized I would have to move it forward a bit in order for any adult to fit in the 3rd row which is fine because the 2nd row is reserved for the pup.
Reclining the 3rd row helps with the comfort, but you're limited in how much you can recline.
Head rests were up, but I didn't know about the short strap. Will give that a try.Were the head rests pulled up?So I decided to climb into the 3rd row to see how it felt. Kinda cramped for an average side adult. It feels like you are leaning toward too.
You can recline the 3rd row a lot in my opinion. More than necessary. Imagine the 3rd row is down for storage. The same strap you use to pull it back out of the floor, keep pulling, and it goes beyond 90 degrees and starts to recline. Or course, the more you recline, the more space you take away from the storage space behind the 3rd row.Head rests were up, but I didn't know about the short strap. Will give that a try.
Its like night and day. Before I found the strap, I was ready to write off the Ascent as an option. Once you recline it, the 3rd row becomes way more viable.Head rests were up, but I didn't know about the short strap. Will give that a try.
Can you put a suitcase behind the 3rd row if you recline the seat enough to be comfortable?Its like night and day. Before I found the strap, I was ready to write off the Ascent as an option. Once you recline it, the 3rd row becomes way more viable.
Not lying flat... but standing up and down, yes. You can even get a couple of 'em.Can you put a suitcase behind the 3rd row if you recline the seat enough to be comfortable?
Yep. Those short straps recline the seat. Makes for a far better ride.Its like night and day. Before I found the strap, I was ready to write off the Ascent as an option. Once you recline it, the 3rd row becomes way more viable.Head rests were up, but I didn't know about the short strap. Will give that a try.
Yes, pull to recline..Yep. Those short straps recline the seat. Makes for a far better ride.
Yes it reclines.The rear seat should be able to recline a bit from what I remember
