Obviously going to call the dealer, but what could possibly be going on for multiple warnings? Check engine light is on, eyesight and RAB are disabled and the x-mode light is blinking. 800 miles, 2 weeks old.
Check your gas cap. Take it off, then tighten it all the way back on, then drive for a bit and see if it turns off. Subaru is VERY safety conscious. If it detects a fault, it shuts off ALL driver assist functions, thus, your dash lights like a Christmas Tree.Obviously going to call the dealer, but what could possibly be going on for multiple warnings? Check engine light is on, eyesight and RAB are disabled and the x-mode light is blinking. 800 miles, 2 weeks old.
Could still be the gas cap, as you use gas over a couple of days and it tests the evap system.Code came back as P24BA -Evap system leak sensor low. Hadn’t filled gas in a few days, so wasn’t gas cap, didn’t overfill either. No damage to lines, so they cleared the code and sent me on my way. They will do more extensive diagnostics if issue should repeat itself.
Ours just did the same thing on Tuesday. Everything back to normal on Weds. I have no clue. Don't have time to take it in. We are over 20K miles FYI. I feel like it has done this before in the past as well. Also, still pissed that we constantly lose the radio presets. That issue has been happening since day one.Aaand again... Yesterday morning, as soon as I cranked up, same as last time. This time the code is P2404, still “evap System leak”. Hopefully I’ll get it in for more extensive diagnostics today.
There’s an update for your head unit, to fix the presets issue.Ours just did the same thing on Tuesday. Everything back to normal on Weds. I have no clue. Don't have time to take it in. We are over 20K miles FYI. I feel like it has done this before in the past as well. Also, still pissed that we constantly lose the radio presets. That issue has been happening since day one.
Ours checks for updates every time we start the car at home, and every time we come back. It happened when we first got it almost a year ago for a few months, then an update came out and I don't remember it being an issue for a while...maybe over winter, but now it is happening again.There’s an update for your head unit, to fix the presets issue.
No, that's not for firmware.Ours checks for updates every time we start the car at home, and every time we come back. It happened when we first got it almost a year ago for a few months, then an update came out and I don't remember it being an issue for a while...maybe over winter, but now it is happening again.
If you have Navigation go to: https://subaru-maps.com/#/updates Click on the center tab for "Updates". If you don't have Navigation the dealership needs to do it. As Robert mentioned, this is a Firmware update and it has fixed the Preset problem. The one that the car checks for at home is for the individual maps for the states you have selected-roads, interstates, etc.Ours checks for updates every time we start the car at home, and every time we come back. It happened when we first got it almost a year ago for a few months, then an update came out and I don't remember it being an issue for a while...maybe over winter, but now it is happening again.
Since it does check the fuel system pressurization, even if the gas cap clicks, you could literally have a bad gas cap. I've only seen that once over the years, but it has happened. And the car doesn't know the difference between a loose gas cap and an actual fuel system leak - it treats those the same way, by turning your dash into a Christmas light display.Aaand again... Yesterday morning, as soon as I cranked up, same as last time. This time the code is P2404, still “evap System leak”. Hopefully I’ll get it in for more extensive diagnostics today.
Mine had been doing the same thing on and off for weeks now. We bought it new just over 1 month ago. The dealer can't get it to duplicate it, and I hadn't gotten gas in just over a week the previous time it happened. The most recent two times it happened. I got gas and the lights went off. 24 hrs later, all lights are back on. This time, I finally got a message sent to my phone to make a service appointment. This never happened before. I am hoping the code is now stored and the service department can fix it this time. I am so frustrated. Do you know what the issue is/was with yours?Obviously going to call the dealer, but what could possibly be going on for multiple warnings? Check engine light is on, eyesight and RAB are disabled and the x-mode light is blinking. 800 miles, 2 weeks old.
Any fix they did?Aaand again... Yesterday morning, as soon as I cranked up, same as last time. This time the code is P2404, still “evap System leak”. Hopefully I’ll get it in for more extensive diagnostics today.
More I own Subaru more I don't understand, why we have to deal with all this issue, we spend so much money, Subaru don't pay as for our time spending with DillerObviously going to call the dealer, but what could possibly be going on for multiple warnings? Check engine light is on, eyesight and RAB are disabled and the x-mode light is blinking. 800 miles, 2 weeks old.
