1 - 5 of 5 Posts
hi
everytime i open the door all the cabin lights turn on. is there any way to turn it off? i tried to set it in setting but nothing happen.
thanks
I haven't been able to figure that one out yet, along w/ many other gizmos. So far, no!
Keep in mind that the cabin lights (excluding the map lights) are not dome lights that you often see in the competitors or in other Subaru lines.
Just in case you missed it... there IS a slide switch just to the right of the 2 front/center dome lights that will turn them(those 2 front/center) OFF and they will no illuminate when doors are opened.
The rest of the dome/map lights will always turn on when doors are opened.
I, on the other hand, am searching for a way to turn on all of the cabin lights without having to open a door. Does anyone know of a way to do this? All of my previous cars had a way to do this with the instrument brightness control, but that isn't so with my 2019 Ascent.
The 2020 models have an interior switch. If you want to retrofit one, check this thread out. I'm not sure if it has the functionality you want (I haven't really looked into this).
1 - 5 of 5 Posts
