any chance you unplugged one of the parking brake solenoids? seems like something was either damaged or unplugged. Did you try and clear the code and see what it does?
I unplugged both when I replaced the rear pads and rotors…could that be my mistake and it needs reset at the dealer?any chance you unplugged one of the parking brake solenoids? seems like something was either damaged or unplugged. Did you try and clear the code and see what it does?
Yes.did you exit EPB service mode with the tool after you replaced the pads?
You’re telling me… we bought the vehicle from the original owner with ~80k miles on it, so I’m guessing they never changed the brakes at all.That’s not a 100k pad… that’s a 100k pad backing 😳
What pads did you put on it? If they’re oem there’s no properly bedding them, it’s just driving without hard braking for 1000mi.
Did you check if the parking brake works, despite the lights/ warnings?
At the dealer now, should know when they get me info. Will update as I know more!Let us know if you fixed this or figured out the problem.
awesome.At the dealer now, should know when they get me info. Will update as I know more!
Interesting….. so it seems to be the rears are just moody? Does your tool have the ability to take it out of service mode?Similar issue with the dash lights. 99k for mileage. put new pads (2nd time) and new rotors (1st time) on the front a few weeks ago, no issues. had to replace the rear pads and rotors this weekend. used the Innova 5610 to place into brake service mode and changed everything out no issues installing. used the caliper tool from Amazon (8MILELAKE Disc Brake Caliper Compressor Wind Back Tool 24pc Professional Disc Brake Caliper Tool Set) to compress the pistons, went in more straight like old school piston rather then rotating in but worked, and buttoned everything up. brought brakes back online compressing pedal slowly thinking that would release service mode. ended up with all the dash lights and couldn't get them to turn off. did test drive to seat brakes and did not notice any dragging on the brakes. had a trailing vehicle to verify brakes weren't over heating so I didn't burn my Ascent to the ground. set up a service appointment online that night for Monday 5/22 to fix my grounding recall. mentioned to them my Christmas tree lights on the dash and they stated they would look at it with a fee for troubleshooting. waited about an hour in the lobby before service advisor came out, recall was taken care of, and they were able to take the brakes out of service mode and all was good, and no charge by the dealer to boot.
Sounds more like the tool didn't do the recalibration and removal from service mode. That will light up the dash.Interesting….. so it seems to be the rears are just moody? Does your tool have the ability to take it out of service mode?
This was the exact issue. Will be addressing a potential software update to fix.Sounds more like the tool didn't do the recalibration and removal from service mode. That will light up the dash.
I tried the Innova 5510 and it would put the car into service mode but scrolling down in the screen the tool said it does not perform the reset function. Interestingly, Innova online customer support said the 5510 with the latest firmware (we confirmed it was) will do it but Innova phone customer service said no, definitely not. In fact, their website compatibility check confirmed it would not do the reset portion. I had a local shop use their fancier Autel tool and they were able to do the reset.This was the exact issue. Will be addressing a potential software update to fix.
