1 - 20 of 23 Posts
Read Only
Any time a phonecall ends, as the infotainment is switching back to radio (sat, media, fm, etc...) there is a fractional second's worth of EXTREMELY loud music (or a blast of static) before it returns to the initial level. The volume level on the screen never reflects any sort of change from the previous level, and the fact that it's usually whatever was playing in the background leads me to believe it's infotainment based, and not from my phone.
There was one time where the music came back on at what sounded like vol:50 and took several seconds before frantically mashing the volume button to turn off the infotainment was successful. Scared the bejeezus out of the kids, too!
This can't be that common of an issue, but I'm hard-pressed to believe that our vehicle is the only one that it has happened to.
Anyone else?
I had this happen with a couple versions of Android auto. And not sure when it stopped happening on mine, but I am running the same firmware on the radio as when it was happening. So, I presume it was an Android auto or Bluetooth issue.
I also hear a short blast of high volume radio at the end of iPhone Bluetooth calls, maybe a half second. I'm pretty sure it's because I have the volume for calls set to near the maximum while the radio is set to around 10. I'm guessing it has to switch from the phone to the radio then set the volume to the correct radio level and that takes a bit of time.
There is probably a more elegant way to do this.
I wonder if I turned up the call volume on my phone and turned down the cars call volume it would fix this?
Read Only
I agree. It's almost as if the transition from phone audio to radio audio defaults to max, and then has lower volume previous setting applied later. This would presumably the eliminated by starting with audio default to a minimum and then raised to previous volume setting. Literally do it the opposite of what it appears to be doing now.
I have had the same issue, but it seems to be resolved with turning up the volume to max on my iphone, while in a phone call and turning down the volume on the headunit.
I just recently experienced this problem out of the blue and came here hoping there was a fix - this seems (fingers crossed...) to have done the trick.??
I usually have the radio volume at 7- 9 but at some point I had maxed out the call volume at 38?. While on a call (parked?) this evening I maxed the volume on my iPhone as suggested and lowered the head unit’s to 15 - voila!
Anyone else?
Mine has been doing this for weeks, I have already had the entire system replaced and the new system is doing this. My 2yr old was asleep in the back seat and woke crying deom this issue.
See the above posts.
A new infotainment system won't fix this problem, but you can prevent it by settng your phone's call volume to the maximum then lower the Ascent's call volume to below 20. When it switchs back to the radio or whatever after your phone call it won't blast out.
Read Only
Discussion Starter · #11 ·
Gary, this may be a selective solution...I have changed my phone volume levels to these settings and it continues to do so.
If any of you have found a true resolution to this issue, please share who your dealership was so that my dealership can figure it out. I have been through 2 iPhone models, am using an Apple chord to connect when I want to use carplay, have tried the volume levels (even having both the radio and phone at their lowest levels). This happens at the end of phone calls and the beginning and sometimes end of texts, both on bluetooth and connected. Most recently, the radio unit was replaced and it still is happening! Beyond tired of it after more than a year!!
2019 Ascent Touring
2019 Ascent Touring
Assuming you have the most recent firmware, this is a known Carplay and Android Auto "ducking" issue. Subaru cannot fix it.
except that it does it when on bluetooth as well as connected via Carplay
Yes, because CarPlay and Android Auto use Bluetooth. I should have said it's an issue with Android and iOS handling the bluetooth streams - most often for Carplay and Android Auto.
If you use Sirius XM or a USB stick, or a CD for music, you will find the head unit works perfectly and audio ducking is perfect (the head unit is in full control since its the head unit's internal players handlng the music).
This comes and goes with my Note10 during various Android Auto updates. It just recently came back.
Ok got it. So, we all just live with this... that sucks.
I'm hoping a permanent fix is implemented. I suspect that they fix it for one set of head unit implementations, and in doing so, break it for another set, and on and on and on. Only one of these various Android Auto complaints is a Subaru, for instance.
4960
1 - 20 of 23 Posts
