1 - 14 of 14 Posts
Me (Ascent) and a buddy (Outback) are planning to go off roading in Death Valley and wanted to purchase some recovery gear. Couple of questions
1) Wanted to get your thoughts on best tool/way to connect a recovery strap to front tow hook?
2) This video (6:13) recommends directly connecting the recovery strap to hitch using the pin. He recommends it over using a ring shackle.
Any other opinions on safe recovery methods is welcome! TIA.
I see no issue using a shackle in the receiver for this purpose, especially on a "light weight" vehicle like the Ascent and similar. It's a bit easier than trying to attach via a hitch pin, too, as well as provides a little more lateral flexibility if the relationship between the vehicle to be recovered and the tow vehicle are not "all in a line" due to site conditions. It also has no "sharp" edges like would be the case coming out of the receiver with the strap.
I can't help with the front hook question and will leave that to others.
Reactions: Titanrx8 and ai2160
The shackle I use is a solid one piece shackle with a ridiculously over-rated (for the Ascent) D ring and a solid pin that locks into place. There's no reason to NOT use one like it for the Ascent, even fully loaded. I wouldn't yank off the front tow hook - gentle pulls on a recoil rope are the absolute most I'd do, but, it's not designed for high force kinetic recovery, and it is absolutely not designed for yanking on a tow (non-kinetic) rope. The TOW point is on the driver's side front of the car, underneath, in front of the tie down hook, bolted to the frame rail.
Also, please be aware that the Ascent is well beyond the towing limits of the Outback, and, the towing points on the Outback are not rated nearly high enough to extract an Ascent.
Some other tips for Death Valley are the following:
  • Have recovery tracks. Tests have shown that the cheap ones perform as well as the expensive ones. Get the expensive ones, if you want ones that have cool mounting solutions (to roof rack, side racks, etc) - otherwise, get a cheap set (two boards/tracks) that's rated well. Most come as a set of two, but, always double check.
  • Air down to the minimum your car can handle. On my KO2's, I can air down to 18 psi or a little less. On my Kumho Road Venture AT51's, I could air down to 20-22 psi.
  • While aired down, do not do sharp cornering at any speed over a crawl - you run the risk of popping a bead off. If that happens, you can get it back on, if you know how, but you will need to have it resealed properly (taken off, and the bead cleaned of the sand, and then put back on).
  • Have a shovel and be prepared to use it. Unbury behind the wheels, and reverse out, if you get stuck.
  • If you get stuck, don't floor it - you will bury yourself to the frame, and it will take hours to dig out, or, you will need something bigger than the OB to yank you out with a recoil rope.
  • Bring extra water (to drink), and, people suggest renting a satellite phone. It's pretty cheap to rent one (including some amount of minutes) for a week.
  • Bring a fire extinguisher.
  • Bring a kinetic rope rated at 2.5-3 times the weight of the Ascent. EG: 15,000 pounds to 18,000 pounds. If you get one that's higher rated, it becomes a tow strap. If you get one lower rated, it becomes something that will snap.
  • Do not have anyone standing within the length of the kinetic rope or tow strap. A kinetic rope that snaps can literally cut a person into two separate pieces.
  • Invest in a better jack for such trips, and a jack board to stick it on.
  • Some people use a winch and sand anchor in places like Death Valley - I haven't tried that.
Here's some of the gear I use:
Kinetic Rope
DON'T
over-rate these. No less than 2.5x max vehicle weight, no more than 3 times max vehicle weight. Mine came in a much nicer bag.
Toss if they become frayed, cut, nicked, etc.
This is one of the highest customer rated kinetic ropes you will find on Amazon.
11780
11776
11777
Tow Strap (non-kinetic)
DO feel free to over-rate these. Mine is rated at 30,000 pounds.
This is one of the highest customer rated straps you will find on Amazon.
11779
BTW, this comes with the BEST locking shackle pin I've bought to date.
11778
Extra Shackles
Except, I have the red one no longer listed. I use this so I have a shackle set in the kinetic rope bag - so, in a pinch, I grab whichever recovery strap is better suited, and there's a set of shackles ready in each bag.
This is one of the highest customer rated shackle sets you will find on Amazon.
11786
Shovel(s)
Cheap but great option
This one is very decent, and I've used it since April 2014 through now - giving it to my brother. It's great if you're on a budget, and has lasted me for almost 3/4 of a decade.
11783
11785
BEST OPTION FOR A COLLAPSIBLE SHOVEL - BUT MORE PRICEY
This one is great, and comes with a lot of accessories, and a handle extension, and can be used as a wood saw in a pinch.
This is one of the highest rated shovels on Amazon.
11781
11782
ERRATA:
Besides all I've mentioned in the last two posts, I also bring mylar emergency blankets and one regular blanket, as well as a full tool set - but, I do more than just day trips, and I can go really far out into nowhere.
Sounds like the pin for the solid shackle will fit right thru the front tow hook and that is how we connect tow strap/rope to it. Please correct me if I misunderstood your post. I didn't think the 'eye' of the front hook is large enough to put the pin thru it. I haven't made any measurements, just eye balled it and I could be wrong.
If the shackle were to break free, wouldn't the driver of vehicle pulling be in danger? a) they are within the ropes length from hitch where rope is attached b) the rope is more likely to snap back and go thru the vehicle pulling, putting the driver at risk. Same for driver in the vehicle being recovered if they are in it (likely) should the rope come loose from the hitch of the vehicle pulling. Sounds pretty dangerous.
On a tangent, you seemed to have gone off roading in Death Valley. Any trial recommendations?
If a shackle breaks free of the Ascent, and you've hooked it to either the recovery mount on the frame rail or to an OEM hitch, you have a much bigger problem. Shackles won't break towing the Ascent, most especially from the hitch. I am very sure that the rope would break first. If you use the Motormic shackles or the Rhino, you'll see why - they're one of the most beastly parts of any recovery solution you'd be using to recover the Ascent (or Outback).
This is the Motormic shackle (and hitch mount). As beefy as it is, the Rhino is slightly beefier. Nothing is breaking on it. These things are beasts.
11790
But, yes, there's always dangers in doing a vehicle recovery. A flying shackle can do irreparable damage to a person, and serious damage to a car, and a snapped recoil rope really and truly can cut someone in half. There used to be a video on YouTube. I had the misfortune of seeing it before it was pulled.
Regardless, I cannot imagine a rope coming loose from a properly used, high quality shackle. There's a very big reason why everything I bought (excepting the shovel) is of the highest possible quality available. Note how thick the shackle pin is, and how much threading holds it in place (the entire thickness of the shackle). And, the shackle mount itself is solid steel, just like the pin and shackle.
I am pretty sure the pin of the shackles I use will fit through the recovery hook hole on the Ascent. If I ever unbend mine, I'll try it.
It may or may not fit through the tie down hooks (but you shouldn't use them there).
I have not went to Death Valley - it was on our list for our 2019 Cross Country Adventure, but, time didn't permit it. We did spend a bunch of time in the deserts in Joshua Tree, and Moab. I do recommend GaiaGPS app (iPhone/Android/Computer), and, downloading the NPS and Gaia maps inside of it. The NPS maps will show you the legal trails and driving areas.
Hi Robert,
I had read a while back that the Accent is not meant to be used with a Kinetic Strap...but admittedly, I never found a rationale for this.
Kinetic Rope
DON'T
View attachment 11776 View attachment 11777
Hi Robert,
Hi, not sure why, as it's gentler than using a tow strap for a recovery.
Funny to see this thread near the top of my feed, as I came on here just to ask about the front tow point. What is it rated at? I wanted to inquire if it is rated enough to be used as an actual off-road recovery point. Whether that be a pull from a kinetic strap or from a winch line.
Kinetic Rope
DON'T
Extra Shackles
Shovel(s)
ERRATA:
On the Kinetic snatch strap, what rating or size do you use? They list then at break point, 1/2in is 7,300lbs, and the 3/4in is 16,000lbs.
Do you use the 1/2in?
I also have the Motormic tow strap kit you list. I have used it to recover my Suburban and a few other vehicles, great kit.
However, I watched a review of the Tyger "Survival" shovel, and in real life use it was not a favorable review. . The solid handle transfers vibrations to your hands when using the Axe feature, the head spins when you try to use the shovel and the knife is downright dangerous. So, do your research and decide for yourself. My favorite shovel is just a standard hardware store shovel that costs less than $35 and you know will work as designed. If you need an axe or hatchet, my favorite is the Fiskers line.
I had the 3/4" 16,000 pound Ditch Pig, but, I snapped it a few months ago.
I switched the Ditch Pig for a 7/8" Yankum.
That's odd - and literally impossible (unless it was horribly mis-assembled by the reviewer). I've had mine for years now, and it does none of that.
Rectangle Font Handwriting Circle Art
The handle has a thick rubber insulated grip (red), a pull lock that attaches the handle to the shovel (green) and multiple locking detents that hold the head in "axe/shovel" or "back hoe" configuration (blue).
White Light Product Automotive design Line
I don't use it much, so, that's perhaps possible?
It is possible, that with all the cheap copies on Amazon, that he was reviewing a cheap imitation of the one you have. He was not impressed with it. However the Tyger may be the original and very good.
If you are happy with it, that's all that matters. It is one of those items you need to have, and hope you never need.
I also think that in this day and age where everything gets reviewed, you can find a positive and negative review of any product. Take it all with a grain of salt.
What is the front tow point rated at? Is it rated enough to be used as an actual off-road recovery point? Whether that be a pull from a kinetic strap or from a winch line.
I can't find that anywhere. I will ask some friends to bug the engineering team. I'd probably harness off the two tie downs and the one tow hook if I was in a big jam that didn't require more than a tow or slight kinetic pull.
1 - 14 of 14 Posts
