Best tire pressure with 51 psi max Defender HIs
1360 Views 38 Replies 10 Participants Last post by  Packard8
Hi All,
I have always run my tires higher than car manufacturer recommendations on the door. Have always had good tire wear - and, likely better MPG than lower pressure. I ran the OEM provided Falkens at 36-38 psi - they looked really even across the tread and I could probably have gotten another 5K out of them when I changed at 35,000 miles two weeks ago.
The DIIs I just got mounted are 51 psi max. I will probably run them at 42-44 ambient after sitting overnight (time of check and fill).
What are this august group's thoughts?
1 - 20 of 39 Posts
Hi All,
36-38 if fine in my "book" but 42-44 is overdoing it IMO , after all pressure calculated based on the car weight/load and travel speed not on max rating of your tire
higher tire pressure = less traction
it also harder on your suspension components
and with 42-44 on cold you likely to trip TPMS as it warms up
  • Love
Reactions: 1
denissh,
What pressure lights off the overpressure side of the TPMS? The sidewalls are 51 psi max - if I inflated to 51 psi, would that activate TPMS? This seems like an engineering mismatch between tire manufacturers and TPMS sensor/computer settings?
I found that TPMS supposedly will activate if your pressure is 20% or 25% (depending where one looks) below manufacturer door markings (haven't found anything specific from Subaru, yet).
Haven't found anything specific wrt overpressure warning, though. Some sites note that not all sensors/computers have overpressure warning capability.
To the suspension - yeah, perhaps that would cause a bit of additional wear, but I would gladly sacrifice that wear for some additional stiffness in the suspension :)
sidewalls max psi got nothing to do with requirements for your car
Reactions: 4
No way would I run a cold pressure up that high on any tire suitable for the Ascent unless it's specified by the tire manufacturer specifically. (a specialty tire) I generally run about two or three PSI cold over the vehicle spec. I did that for the Defender LTX on my previous vehicle (36 --> 38) and would likely do that on the Ascent for the Defender 2 (33 --> 35/36)
Denissh is correct that max pressure on the tire is irrelevant to what's appropriate for the vehicle you're mounting it on. On the vehicle, it's a combination of weight, suspension characteristics, etc.
As explained on this Tire Rack reference page (https://www.tirerack.com/upgrade-garage/what-is-maximum-load-inflation-pressure-for-a-tire), the "MAX PSI" branded on a tire's sidewall indicates the maximum COLD inflation pressure as a reference. This in-turn carries relevance to the max load rating of the tire - https://www.tirerack.com/upgrade-garage/what-is-maximum-load-for-a-tire.
However, this number doesn't take into account the handling characteristics that your vehicle was designed with via its various engineering parameters, so filing your tires to this pressure can potentially cause some wonky behavior, especially at the limits (i.e. in true emergency situations, where we by-definition push the tires close to their 10/10ths).
This in-turn is where the vehicle's door-placard recommended pressures comes into play: however, this itself has the caveat of being valid only for the OE tire and tire sizing.
Going aftermarket can potentially cause things to change, here.
The sad truth is that while we all think that we can subjectively judge our tire's "feel" through our input behind the wheel, it actually takes A LOT more skill and knowledge to tease out such characteristics - skills which the manufacturers literally pay actual professional test drivers to assess. Unless one's driving record/CV/résumé as a professional or amateur actually reads of a similar caliber, one is just fooling themselves - and this is something that the experts at Tire Rack have said in so many words on NASIOC, where the crowd is tough and nobody minces words to save anyone's feelings. 😅
That said, practically speaking, inspecting tires for incongruous wear patterns as we change its cold inflation pressures can give a pretty good indication of whether the (specific aftermarket or OE) tires are being optimally inflated for our manner of driving. Here, it's important to not just "look" at your tires, but rather actually take some measurements using a tire tread depth gauge. While gross issues can usually be readily seen, particularly by experienced eyes, judging depth isn't something that can be done accurately in any way other than measuring (which is why tire techs actually use gauges!). Be aware that the tire will wear differently in different spots, so taking measurements in different locations around the tire is important: typically, inner/middle/outer measurements are taken. Similarly, remember that there's going to need to be some level of grace given to our skill to measure accurately as well as how "sensitive" the instrument itself may be: with gauges that measure in 32nd of an inch, understand the real-world (in?)significance of a 1/32nd difference, when measured in this way.
In terms of the overpressure warning, I've yet to see it on my Ascent, but I did once see it on my '16 Outback 2.5i Limited, as I sat in "car line" waiting for my daughter to be dismissed from summer camp, with one side of the car baking in the hot sun, on asphalt, while the other was in the shade afforded by the building. This is a tale that I've relayed many times both here as well as in the SubaruOutback.org community. IIRC, TPMS read the pressure on the sun-baked side somewhere north of 45 PSI. IIRC, there's at least one report on SF.org of someone seeing TPMS warn at 45 PSI.
I haven't run my current 245/60R18 Falken Wildpeak A/T Trail at 36 cold for long enough to really get a good feel, but at 37 cold, I would routinely see them at around 41-42 PSI via the dash TPMS readout, running on 80-90 deg. F., ambient, sunny days. I've never seen TPMS warn at such pressures, even after extended driving.
I tried to rip the max/min warn values from the ECU via my AUTEL TS508, but I couldn't remember how to do so (or even if it is possible). I'll check back here if I find a way. :) With TPMS tools like the TS508, I know that there's the ability to re-write the placard value (to correspond to out-sized changes in tire specs), but I haven't seen anything about reading or modifying the max/min warning values.
See less See more
  • Helpful
Reactions: 1
A good rule of thumb is your pressure should rise 10% from cold to hot. Unless you're running an LT tire, I'm pretty sure if you run 42 cold you won't see a 4psi rise when hot, meaning your tires are overinflated.
Reactions: 2
An interesting topic!
While searching got "truth" or at least some technical discussion on the topic, I came up with - well, not much 😱 The usual internet provided articles, however, there were a few consistent themes and statements from a variety of companies, organizations, forums, etc.
One can almost sense the authors of the many articles avoiding legal liability for their comments.
Paraphrasing a few:
1. Vehicle manufacturers try to pick a sweet spot for mpg and comfort
2. Vehicle manufacturer recommended pressures are minimum
3. Modern tires have lots of margin (but no clear numbers)
4. Higher pressures than posted on the car, to a point, improve mpg
5. Higher pressures result in less relative pressure increase with driving as the tires flex less, creating less heat, so more heavily loaded vehicles should have higher pressure
6. Too little pressure creates flex in the tires leading to potential failure with accelerated heating
7. More pressure could impact comfort (did not see any mention of damage to suspension, though)
8. Lower profile tires benefit from more pressure to help prevent damage from things like potholes and curbs
9. Many cited "sidewall minus 10%" as optimum
10. Found almost nothing on TPMS device standards, or when overpressure warning would occur (am assuming thus may be related to different implementation by vehicle OEMs?)
11. Overpressure relative to load results in more wear on center of tread face. No tests found that might look like this: take an Ascent, fill fuel tank, load to a percentage of max, then inflate tires until the form of the tread begins to curve causing more wear in center of face, then increasing load on vehicle until face of tread flattens to optimum. Leaving a lot of test points and analysis opportunity out of this very brief "what if"
12. Picking a pressure and driving until, over time, the wear pattern can be determined, is probably the only way know for sure - however, so many inconsistencies might affect this?
See less See more
Reactions: 3
Paraphrasing a few:
it's not an interesting topic at all, almost 2+ times a year in almost every car forum
Almost every line is wrong ...
Overpressure results in smaller contact patch = no traction = unsafe car
P.S you should have owners manual
you do you ... but i am done on a subject
Reactions: 1
denissh,
I will miss your inputs on this topic! :)
I should note that there are many who disagree with your complete adherence to the owner's manual. Perhaps just a difference of opinion based on various technical backgrounds of those commenting?
This quote from you is a bit binary, don't you think? "Overpressure results in smaller contact patch = no traction = unsafe car". Depending, of course, on what you perceive as "Overpressure" which is subjective. For instance, if one inflated 51 psi sidewall tires to 45, if you think this is "overpressure" then it would have "= no traction" and be "= unsafe?"
Empirically, I'm seeing just slightly more - but that could be the variance in the TPMS.
Reactions: 1
Sounds like the 10% estimate is close enough for the measurement devices we are using. I, too, have seen pressures rise greater than 10% from ambient to hot, but not much more.
I may add a bit of slop, and go with 42-44, try it and note increases during hot driving and then modify as dictated.
Reactions: 1
Tires always are! :)
Yup. Tire science is really, really interesting - Sport Compact Car dedicated a whole half-issue to write this up a couple of decades ago, and they conceded that they were barely scratching the surface. The amount of money these tire behemoths throw into their testing and development is just mind-boggling: I was given an insider glimpse into it some 12 years ago, and it just floored me.
In any case, let's continue this most interesting discussion.....
Back when Subarus were shod with Bridgestone RE92s (BL/BP Legacy, GD WRX), there were numerous reports of blow-outs related to sidewall damage occurring from slight overinflation (i.e. what hobbyists/enthusiasts would consider reasonable as a "corrective measure" to the perceived shortcomings of that OE tire/fitment) . Conventional wisdom seemed to fall apart, there...but yes, slight over-inflation has always been the "rule of thumb," in terms of helping low-profile tires with pothole/curb damage.
Just as any other such "rules," empirical evidence may really call it into question (more, below); yet, still, it's often a good place to start, if we can only keep from approaching it in a dogmatic manner.
The other popular one is "sidewall minus 20%."
The problem I find with this is that it's an absolute based on the tire's load limit, but discounts any input that the vehicle manufacturer may have in terms of the vehicle's handling and performance (these in-turn translate into safety) characteristics.
However, it is much better at giving folks a reference point to start from when non-OE fitments come into the equation.
The most recent personal example I can give is the following. The max pressure branded on the Falken Wildpeak A/T Trail at 245/60R18 is 51 PSI. Filled to 37 cold and routinely checked, at just shy of one year of road-use (3-seasons, excludes winter, as I have a dedicated winter set), with approximately 3K miles on the tires, the tire shop measured tread depths of 10/32", 9/32", and 10/32" (out/mid/in; here I specifically cite shop [Tire Rack affiliated local NTB branch] measurements because I am purposely taking myself out of the equation), when I made a road-hazard claim (Falken AT Trails on 18" Wheels - what's your...).
How's either "rule of thumb" percentages working out with this one, versus empirical evidence? ;)
Same as my search from last night Into this morning. I think you're right, in that this ties into the vehicles parameters more, so it's just not there. I can't get my TS805 to pull this from my Subarus, and I don't see any mention of it in its general documentation, either, for other marques.
Empirically, this has been my own experience over the last 30 or so years, with various vehicles, with direct tread depth measurements. However, whether not being blinded to the results, my own (lack of 😅 ) skill and other inconsistencies (what you'd cited in point #12) could potentially have caused bias, I honestly can't rule out.
And that's what I want to leave off with, this reply -
Many times, we conflate what we see/feel with what actually should be. How many times have we read here that folks want to over-inflate their winter tires so that they can reduce the "marshmallow feel" of their winter tires in corners? Isn't the actual purpose of winter tires to increase one's safety margins in wintry conditions, versus cutting sharp corners in the clear?🧐 Alternatively, we want to fight empirical evidence and hard data with the butt-dyno, like when Dave Buschur posted dyno runs after dyno runs years ago on NASIOC to disprove the supposed power enhancements of popular "Short Ram Intakes" (SRI), repeatedly showing that heat-soaking actually prompted the ECU to pull timing.... No-one wanted to actually see the data, because they wanted to believe that the extra induction noise they were hearing was actually the vehicle producing more power.🤯
As a benchtop scientist, I'd prefer that I take my feelings and beliefs out of technical conversations.
But I know that no matter how hard I try, it will always color such exchanges. :)
See less See more
its just math ... for simplicity forger tire are round and have tread and patterns ..
5000lb / 33psi = 151 / 4 tires 37.8 sq in per tire (6.1x * 6.1x)
5000lb / 51psi = 98/4 tires 24.5 sq in per tire (4.9x * 4.9x)
it's over 25-50% reduction in surface contact area
Most likely...yes. The vehicle isn't heavy enough to support that level of pressure and have a normal contact patch. Going up a few pounds is generally fine, but beyond that it truly can affect wear. My reaction to the list you published was pretty much the same as Denissh's.
So, the concept of "no traction" makes sense :)?
No being sort of binary, right?
Sure do seem to be a lot of folks who use different math than denissh.
Again, the recommended inflation pressure for OE-fitment tire/wheel combo that's displayed on the vehicle's door placard is the vehicle manufacturer's recommendation for both safety and comfort.
On the other hand, the tire's rated max pressure as it is embossed on the tire's physical sidewall has completely different implications -
The max pressure branded on the Falken Wildpeak A/T Trail at 245/60R18 is 51 PSI. As I wrote above, empirically, when filled to 37 cold and routinely checked, with approximately 3K miles on the tires, the tire shop measured tread depths of 10/32", 9/32", and 10/32" (out/mid/in) on my tire - which was exposed only to normal weight loads. Empirical evidence would suggest that running my tire pressure higher than 37 cold would have resulted in further centerline wear.
Similarly, with your OP, @AscentForumUser , you noted that you inflated your OE Falkens to approximately 36 to 38 PSI -
* emphasis added.
The OE Falken Ziex ZE001 (245/50R20 fitment) also lists max inflation pressure at 51 PSI.
Per the "10% of maximum" rule that you'd mentioned in a follow-up post, that would be ~46 PSI.
Per the "20% of maximum" rule that I also mentioned seeing in my response to that follow-up, that would be ~41 PSI.
Both of these values exceed your reported 36-38 PSI fill for the OE tire.
You reported that you empirically observed (i.e. "looked") even tread depth across the width of your outgoing OEs. Similarly, you suggested that you likely could have kept driving (I would assume safely; which I will in-turn assume you mean that they would remain above wear-bar depth) on the tires for another 5,000 miles beyond your replacement mileage of 35,000 miles (which comes in at the high end of the spectrum for what most drivers here and on the Subaru Ascent Facebook Group repot). That you specifically mention these observations would lead me to believe that you are happy with what you'd seen, at the tire pressures you'd used with the OEs.
Logically, then, why would you bump up the cold fill pressure on the D2s to the 42-44 PSI range, as your initial test range, particular as you are, I assume, maintaining OE sizing ?
As @denissh noted in the initial follow-up to your OP, the recommended fill pressure for OE-fitment sizing is something that the vehicle manufacture calculated and tested for the vehicle's typical loads and speeds - not the tire's maximum. Similarly, as noted in both the tire manufacturers' informational pages as well as that of various mentions in the tire resources pages at Tire Rack, @denissh 's mention of reduced (or at the very least altered) vehicle performance characteristics as well as the likelihood for tire damage/increased wear also increase with over-fill scenarios (by-extension, wheel and suspension component damage may also occur if the tire carcass fails, however, any extra shock is also transmitted through those components).
I honestly don't see the logic in going that far over, especially as your own empirical evidence suggests that a cold fill pressure that's less aggressively over the manufacturers' recommendations as printed our door placard has already given you good performance.
I had Discount Tire rep measure the Falkens at 35k just prior to replacing.
I had in my mind they were rated at 44 psi on the sidewall.
Reactions: 1
So that's even better, then, as empirical evidence - it was an actual measurement taken by someone who supposedly knew what they were doing, versus a simple "look/see." :)
Mine are on the bottom of my tire stack, and I'm too lazy to unstack this time of night, so....
Rectangle Font Parallel Pattern Number
See less See more
Meh - I'm pretty ok at judging tires. Not too terribly difficult to eyeball.
1 - 20 of 39 Posts
