1 - 20 of 34 Posts
Hello,
I have been reading all the battery problem posts and just do not want the headache, if I am one of the lucky ones.
What do you recommend to be the Best Battery to buy to replace the Ascent Battery and why? Thanks for all your comments
Hello,
Here are my suggestions. I was going to buy the Optima but for one third the price I went with the highly rated EverStart MAXX-35N (North).
Then it's likely the Johnson Control batteries, aka big box store batteries. Those tend to last about 3yrs +/- several of months.
I'm trying out Interstate battery now on our 2016 Forester.
Johnson Controls makes batteries for vehicle OEMs, big box stores, branded batteries, the military, you name it. They will make any battery to the purchaser's specifications. So if Subaru said they wanted 500,000 batteries as inexpensively made as possible, that's what they would get. If Walmart ordered 900,000 batteries with superior specifications for their high rated MAXX-N line, that's what they would get. If Bosch ordered 30,000 batteries with the best possible specs, that's what they would get.
So you can't judge a battery based solely upon the manufacturer. Nor can you judge a battery based upon battery brands, year to year. For example, Sears might decide to switch from Johnson Controls to Interstate to make their DieHard line. They probably go out for bids every few years.
Here is a list of major automotive battery manufacturers.
Wall-mart site says this battery doesn't fit Ascent....?
This seems to be the ascent battery spec although it probably is a different manufacturer: http://uplusbattery.com/pdf/sli/automobile-battery/jis-series/75D23L.pdf you can compare the sizes from the charts or simply go there to see if it would fit and can strap down.
group 35: 9 1/16(L) x 6 7/8(W) x 8 7/8(H)
group 75:
[TD]
75​
[/TD]
[TD]
Auto​
[/TD]
[TD]9.1[/TD]
[TD]7.1[/TD]
[TD]7.3[/TD]
[TD]230[/TD]
[TD]180[/TD]
[TD]186[/TD]
[TD] 17 [/TD]
[TD]L/H-POS[/TD]
[TH][/TH]
[TD]SIDE[/TD]​
1 - 20 of 34 Posts
