1 - 3 of 3 Posts
I have the base model purchased in Feb this year. I want to add the power lift gate to it.
is it too late to add now at the dealership or is there an aftermarket option?
I recommend going through the dealership.As far as I know there isn’t a aftermarket system outside of Subaru.
Plus if you get it installed by the dealer you’re covered in case something happens.
There are aftermarket solutions to retrofit it onto your base model. Based on google, no human have put together a kit for you yet. However, here’s a pathway for DIY:
1. Figure out the engineering specs (ie load rating and length) of the existing shock;
2. Research online and buy appropriate ones (everybody appears to use the same controller); and
3. Watch some YouTube on how to install them as a mean of obtaining the “Limitless” pill.
If you prefer a shop to install it, go to a mobile security shop and get consultation.
GL
1 - 3 of 3 Posts
