That is SO beautifully done!!! Thanks for sharing all the details!!!
Up through the tailgate, joining another harness, into the driver's D pillar, coming out in the framework near the rear AC unit. It's an analog camera, using four wires back to the head unit. Two are standard 1V signal wires, two are 6V power wires.Does anyone know if it's possible to plug an OEM camera into the existing camera port, but run it through the bumper like OP did? Does the OEM camera run up through the tailgate and down the C pillar?
You can plug an OEM camera but that means you would need to purchase the harness and figure out there it connects before it reaches the tailgate. I was going that route but I couldn't figure out which harness to purchase Subaru Ascent rear harness and I didn't feel like spending $135.Does anyone know if it's possible to plug an OEM camera into the existing camera port, but run it through the bumper like OP did? Does the OEM camera run up through the tailgate and down the C pillar?
I thought about doing this but I would rather use it for of road purposes. I would also want to activate the camera on demand, not only when it's in reverse. I have an extra OEM back up camera I could use but I'd need to figure out which harness/wires use.Could one add an OEM backup camera to the front of the car and mount a selector switch on the dash? I sure would like a front camera for parking.
Use the oem front camera from the Touring instead. Also 6V. And, it will mount in at least Premium and Touring with just one hole drilled (the mounts are in the back).Could one add an OEM backup camera to the front of the car and mount a selector switch on the dash? I sure would like a front camera for parking.
I was hoping to do the same - would you mind sharing which products you did purchase to make this build happen? I might try to replicate what you've done here, but mount the camera to the top of the tailgate looking down.You can plug an OEM camera but that means you would need to purchase the harness and figure out there it connects before it reaches the tailgate. I was going that route but I couldn't figure out which harness to purchase Subaru Ascent rear harness and I didn't feel like spending $135.
For that, you might want to consider the Touring's OEM inside top camera, and the replacement trim housing for it. It will package it neatly away inside the car, behind the glass, and in the wiper zone. It gives a great wide angle rear view image, like looking at the rear view camera, but can be digitally angled downwards to look down.I might try to replicate what you've done here, but mount the camera to the top of the tailgate looking down.
