If you haven't tried the AVH feature yet, do it! It is quite nice. It is the button labeled AVH right above the shifter. Once pressed, you will see the on green status on your instrument panel right side.
Once on for example, when you are at a red light, release your foot on the brake pedal and the car will remain in place. Then when the light turns green, just press the gas pedal and the AVH will automatically be disabled and car will move. AVH will remain on until you press the button again to turn off so any time the car stops, your right feet can now rest!
