Hi, just bought a new Ascent premium for family hauling and towing a trailer which is about 4000 lb fully loaded. Had a Subaru hitch installed. do I need to install anything else for equalization and anti-sway?
The Ascent has anti-sway technology built in that's pretty impressive. I will warn you, it's weird at first. The car will squat a corner or two against a sway - that's not what it's really doing, but that's what it feels like. In reality, it's using the ABS system to brake particular wheel(s) to pull the car the opposite direction of the sway.Subaru doesn't want you using a WDH with the Ascent. There are a number of threads in the Towing forum area here that you'll find helpful.
The ball mount no longer is included with the OEM hitch kit. You need to buy a rise/drop that properly levels your trailer. I use a 4" drop with my boat so the Subaru 6" wouldn't have been useful regardless. Use a ball mount that tucks the ball as close to the bumper as possible. The longer the mount the greater the multiplier for the tongue weight. Excessive tongue weight has to be considered when the car has a 500# maximum.I'm getting a Subaru trailer hitch in stalled on my new Ascent at the dealership tomorrow. Has everyone used the ball mount the come with the hitch or have they had purchased adifferent one. I have a 2015 Coachman Clipper 17FQ.
Lots and lots of folks have done that. The ball mount "size" you need depends upon your trailer. For example, a 6" drop ball mount (what the OEM ball mount was when it was included with the Ascent in MY19) puts the ball at about 18-19" above the ground. Some trailers are fine with that; some require a higher ball height and a few actually require a lower ball height. So you have to actually measure the trailer's expected ball height when the trailer is leveled properly. Some folks buy an adjustable height ball mount so they have the flexibility with just one to use multiple trailers with different requirements.Has anyone purchased a ball mount, but not from Subaru? What kind and what size?
Thanks, the Ascent owners manual says only to use the Subaru brand, But I was wondering if others have purchased different manufacturers brand and what kind. Thank you for your feed back.Lots and lots of folks have done that. The ball mount "size" you need depends upon your trailer. For example, a 6" drop ball mount (what the OEM ball mount was when it was included with the Ascent in MY19) puts the ball at about 18-19" above the ground. Some trailers are fine with that; some require a higher ball height and a few actually require a lower ball height. So you have to actually measure the trailer's expected ball height when the trailer is leveled properly. Some folks buy an adjustable height ball mount so they have the flexibility with just one to use multiple trailers with different requirements.
