1 - 15 of 15 Posts
Mine didn't. I had to turn off auto update and set the clock manually. If I enabled auto update, then the clock set itself back to the incorrect time. My phone did show the correct time during the whole exercise.
Tried running the starlink app but that didn't help either.
Yes, my Limited with Nav updated over the Bluetooth iPhone link.
Mine did too. There's a setting to have the clock automatically update to your phone's time. I toggled this on when I was reviewing all the setting after I first got the Ascent.
did we ever come to a concensus what causes the head unit to sync the phone's time with the vehicle's? my time did not update on its own yet after 2 drives on sunday. i'm going to play with it to see if it updates after doing something specific
Although I can't find the reference now, I'm pretty sure I read that it will sync the time if you have Show Notifications turned on in your phone's Bluetooth settings for SubaruBT. That's the way I have my iPhone set up and it worked with the time change and also crossing time zones. This may also required you too have your contacts downloaded as well but I'm not certain about that.
Reactions: xydadx3
Now that you mention it I recall that being mentioned. I'll give it a try tomorrow when I'm back at my car and see if that works
Reactions: GaryInMI
According to the manual, Press the home button, select Settings, select Vehicle, select Clock Adjustment, then select Auto. With Nav systems, the clock will be set by the GPS receiver. For others, the clock will be set via bluetooth from the your paired phone.
Whenever I enable auto setting via bluetooth, the clock goes back to last week's time
The first time I set my clock to auto update via bluetooth it went to a random time; it eventually figured itself out when the time actually synced with my phone again. Could be similiar behavior for you. I'm still waiting to get back to my car to fiddle...
Update: I connected my iPhone this evening with Bluetooth notifications off and the clock was still off. I enabled notifications and nothing happened. Only afterward when I disconnected the phone via the head unit then reconnected the same way did it update. Problem solved ?
Reactions: GaryInMI
1 - 15 of 15 Posts
