1 - 6 of 6 Posts
Does the Subaru trailer hitch impact the ability to fit a full-size spare? I've looked at the install materials and a video and see it replaces the rear bumper beam but I can't make out whether it intrudes any into the spare tire well.
Also, has anyone been able to fit a slightly larger 30" diameter tire as a spare? I'm thinking of using a 235/65-18 spare to match the diameter of the 255/50-20 tires we'll likely upgrade to. That way it's a little narrower so it doesn't protrude from under the bumper as much and weighs less, but still has the full diameter and load rating needed. But if I can't fit it that might make me re-think moving up to the slightly larger tires.
You can try taking one of your oem tires off and putting it under there.
The 235 spare you鈥檙e considering would protrude downward 1cm less than the oem and you鈥檒l be able to gauge if you have 12mm clearance for the larger diameter.
To partially answer your question, the receiver does not protrude into the spare tire well. Theres a metal piece between the receiver and the spare tire that doesn鈥檛 get moved during installation.
No, a full sized spare will still fit. I have the OEM hitch and a full sized spare. Make sure to leave it deflated, and carry a small air compressor.
Hi Robert and all, hope you guys don't mind me bringing up an old thread. I have a 2020 Limited with factory tow package. I will start towing a 16 foot fiberglass trailer beginning this Memorial Day weekend and throughout the summer. I want to have a full size spare with me in case of a flat. If I get the OEM 18" wheel that looks exactly like the ones I have on, would it fit the spare tire compartment with air deflated (or does it require a different spec spare)? If so, would the OEM wheel sticks out much further reducing rear wheel clearance?
Since the pandemic, I haven't drove my car much and it's now just under 3000 miles. If I get the full size OEM 18" wheels and tire, should I include it with the regular tire rotation? Thanks so much. 馃檹
-Peter
Edit, I think I have an 20" wheel instead of 18". Would things be different in this case? Is the current spare donut spare I have matched the 20" wheels?
Attached is the picture of my car when I picked it up.
Wheel Tire Car Land vehicle Vehicle
1 - 6 of 6 Posts
