Does anyone know if the Android Auto is wired or (dare I hope) Bluetooth?
I believe @Robert.Mauro said the connection is wired.Does anyone know if the Android Auto is wired or (dare I hope) Bluetooth?
Yep.You can still listen to music and make phone calls, read text, etc with just bluetooth. The actual Android Auto interface needs to be plugged in before you can access the maps and everything you see within that menu.
That's a good read. Thanks for that.Wired due to the fact it uses a lot of power and BT may not be able to stream it well enough.
https://www.extremetech.com/mobile/...ess-android-auto-but-almost-no-one-can-use-it
