never used it, didn't know about it, although i might be interested if it plays "Take On Me" non-stop.
'Cause that's really not so much of a thing at this point (since like 2019) after they moved to making updates via both WiFI and USB memory stick available.The thing is that it's supposed to update the system, which, in my case, hasn't been done!
If you know of a way to remove these unused, factory embedded apps, please let me know,Thanks, Ill erase it right away!!!
I believe you can just move them to a 2nd page on the home screen so they're out of the way.If you know of a way to remove these unused, factory embedded apps, please let me know,
As you are rearranging apps, the trash can is on the bottom labeled delete or something like that. Just drag the app towards the bottom of the screen.If you know of a way to remove these unused, factory embedded apps, please let me know,
Thanks for the tip, but when I looked for the android app, it seems to be a paid subscription service.So the other good thing about it, is that you can use it as the conduit for firmware updates. Having the NAV, but no longer a NAV update subscription, I have 2 options, update via WI-FI with the car running in the driveway, or update while driving via the AHA app on my phone. So I would much rather download and update while I am driving. You don’t have to use the app to stream anything, just need to have the phone app open, and then on the radio settings page, check for updates.
Good question. When I searched for the app on Google, the only thing I found was "AhA", with an accent over the "h", and it was from India and in Hindi. When I try to use it on the car's app screen it tells me to first open the app on my phone. Hmmm, hard to do. Seems like companies the size of Subaru, HK, Fuji, etc could keep a bit more up to date with their IT stuff.AHA app is not even available on the newer Android versions. Why is it even being included on Android Auto screen?
Mine isn’t nav either, and updates via wifiMy head unit never updates on WiFi.. and mine isn't a Nav unit so no DIY USB updates.
I can only update via Aha if I don't want to pay the dealer.
