it was used less than 5k miles. This is the DRY filter, NO oil needed,
ASKING 60 Shipped or local pick up. Located in MD
- Fits:
2018-2020 Crosstrek 2.0
2017-2020 Impreza 2.0
2018-2020 XV 2.0
2019+ Forester 2.5
2019+ Ascent 2.4T & 2.5
2020+ Outback 2.4T & 2.5
2020+ Legacy 2.4T & 2.5
The aFe PRO Dry S Air Filter replaces the factory paper air filter, which amplify's the engine induction acoustics, quickens throttle response, lowers intake temperatures, can increase fuel mileage and can increase power.
Unlike oiled filters, the aFe PRO Dry S Air Filter will not damage sensors in the intake track.
If you do not remember the last time you replaced air filters, it is probably time for a replacement. Replace your factory air filters with aFe Filters for a fraction of the cost of factory paper air filters. aFe Filters never need to be replaced and the service interval (for cleaning) is usually longer than the life of paper air filters.
aFePart No: 31-10327
aFe washable and reusable Performance Air Filters feature a state-of-the-art design of layered, oiled cotton media engineered to improve airflow and capture contaminants, and are designed to provide an increase in horsepower. Each performance air filter is reusable and engineered to last for the entire lifespan of your vehicle. aFe drop-in replacement filters are designed to install easily into your factory air box. Upgrade today and start enjoying superior airflow and superior performance from K&N’s most popular product!- Designed to increase horsepower
- Washable, reusable, and engineered to last for the life of your vehicle. No oil necessary!
- Designed to provide high airflow and exceptional filtration
- Engineered to fit easily into your factory air box
- Only needs cleaning every 50,000 miles under normal highway driving conditions
- Emissions legal in all 50 States
- Will not void vehicle warranty
Air Filter Shape Panel Filter Material Cotton Gauze Washable Yes Height 1.563 in (40 mm) Outside Length 9.125 in (232 mm) Outside Width 8.656 in (220 mm) Weight 1.3 lb (0.6 kg) Product Box Height 11.56 in (294 mm) Product Box Length 10.44 in (265 mm) Product Box Width 1.75 in (44 mm)
