A new record?
4.1K views 23 replies 10 participants last post by  Daniel Acosta
#1 ·
I was hoping to break 30mpg this week at Yellowstone, and have actually exceeded that by a huge margin. Keep in mind these are the most ideal driving conditions you can get for fuel economy cruising around at 45mph.
Our 19 Outback 2.5 got 38mpg here, our 20 Outback 2.5 got 39mpg here. The Ascent is on track to hit between 33-34mpg by the time we leave tomorrow. I always fill up outside the park, cruise about 120 miles a day for 4 days, then fill up after leaving the park. I wasn’t sure the Ascent could do this with its lower economy than the Outback and only a slightly larger tank, but it looks like I’ll end up with at least 100 miles to spare because its economy has been way better than even I was expecting.
Today’s log showing 37mpg is only for about 120 miles, but the 340 mile estimate to empty for half a tank is pretty accurate. Right now I’m sitting at 33.5 for the first three days, so by the time I do another 100+ tomorrow and fill up outside the park I’m pretty confident it will stay in the 33-34 range.
Along with exceptional economy, the car has been great in every way for our 3 week, 6000 mile trip. We had one highway leg that hit 29mpg, but several using ethanol that only got 23.
I don’t know why the tire pressure isn’t showing, I run 36 cold all around which equates to 39-40 hot.
#5 ·
That's really excellent, Daniel. You're spot on mentioning the speeds, too. It really can make a "yuge" difference when driving what is essentially a very heavy brick because it greatly reduces wind resistance which is one of the biggest challenges for fuel economy.
#6 ·
I bet it's more than aerodynamics. When the speed is higher than 70mph it consumes fuel like a pickup truck, however, when it's slower the mpg is way better than a pickup truck at the same speed. In other words, the Ascent's mpg drops faster than similar mid-size SUVs as speed increases.
I guess it's related to more frequent turbo usage due to the underpowered engine compared to the competition (despite slightly).
#12 ·
Pro tip. I've noticed with both my Forester and my Ascent I will get a good bit better mpg if I switch into manual mode and force it to the top gear ratio.
However, I am slightly concerned that the transmission may be not keeping it at the top for a reason. For instance am I forcing more wear on the transmission by forcing it into the highest ratio? If anyone out there know more feel free to share.
#14 ·
The programming looks for what is optimal "in the moment" in the combination of ratio and RPM for most efficient travel. Contrary to what might seem to be the obvious choice that lower RPM is better, sometime (more often than imagined, actually) a higher RPM and "easier" ratio brings the best combination.
Yes, we always use 100% gasoline with no ethanol as long as it’s available.
It's nice that you can get it.
#24 ·
Fuel economy on our 23 continues to impress. 360 mile trip today through the mountains, lots of uphill and downhill. I use the paddles to control speed downhill and leave it in drive uphill. Speeds were mostly around 70, no more than 80-85, occasionally 65. Average for the day just under 29. Trips under 5 miles only return 20-21 while the engine is warming up, but otherwise it’s not too hard to get decent mileage. Didn’t notice any difference when we replaced the Falkens with CC2’s about 21K miles ago. 39 is the hot pressure after driving all day, 36 cold on 18’s.
