1 - 15 of 15 Posts
Can someone get a picture of where the 3rd row USB ports are in relation to the cupholders/side walls? And if anyone has chosen the option to get the extra (7th and 8th) USB charging ports, can you show where they are located? If you didn't order or have them installed, is there a place already there for the DYIer? Just curious and thought about adding the extra set to our Touring order. Thanks!
Hmmm...yeah, I've see that circle indentation. That's weird.
I'm told it's not a DYI install and after looking at the instructions, I'd agree. It's more than pull panel, cut hole, install ports, plug into jack. You gotta take out seats and shiz ...
I'm beginning to think it's easier to buy extra long USB cables and run them from the passenger side on the 3rd row over to the driver's side.
Thanks! Not sure if I'd really need it, but if I ordered them and port installed, it might be a good selling point if I decided to sell in the far distant future.
Meh, not sure that it would get you any more if you sell - 6 is pretty darn good and more than any other that I've been tracking. Honestly, I would've rather had two in front, three in middle and three in the back - one for each passenger. Having two in the second and four in the third is a little odd - though I admit I don't know how you get three in the third because there's no center console back there.
Agreed, it is odd to have 4 USBs for the back seat (that I'll never sit in). I was just thinking of a potential tailgating scenario where I might have several devices plugged in, but really, I just need to come back to reality. Thanks! I'll probably skip this option now. :smile:
Well, while you're b.s'ing, there is that 12v outlet in the hatch area that you could put a 2 USB plug into ha ha ha (as well as the 12v in the front where 2 more could go). So, looks like 12 USB is really the max you could get ... unless you got the 120v option and then you could add another 6 or so there ... ha ha
Taken from Amazon (https://www.amazon.com/Subaru-Ascent-Charging-H671SXC000-Genuine/dp/B07G4DCFH4)
Can anyone confirm if this is the genuine SOA 3rd Row USB installation? And if so, what is the round indentation you can barely see on the right edge of the photo (just below midpoint, not the square cargo cover slot)? My 2020 doesn't have the 3rd row USB, but it also doesn't have any indentation or knock-out where the USB is installed in the above photo.
My 2019 Limited has the 2 rear seat USB ports on the passenger side in a shelf cut out, see my photo.
Your photo shows them on the driver's side and looks pretty DYI to me.
The round object on the edge of your photo is the zone 3 temperature sensor.
1135
That is a real Subaru accessory (H671SXC000).
The round indentation you're asking about is a rear temperature sensor for the HVAC system.
1 - 15 of 15 Posts
