Can anyone confirm if the Captain's chairs on the second row on Limited trims come with the hold / grip handle ? I've only seen them on the JBL Touring we test drove and found that to be very useful..
Thanks..
Thanks..
As far as I know YES, all the trims with Captain chairs will have the grip handles.Can anyone confirm if the Captain's chairs on the second row on Limited trims come with the hold / grip handle ? I've only seen them on the JBL Touring we test drove and found that to be very useful..
Thanks..
As well as my 7 seat premium Package 12---Love themYeah, they do. I have a Limited as well.
Love the 2nd row captains chair but hate that they don't fold down nearly as flat as compared to the bench but not a deal breaker.
I believe it has to do with the bolstering on the sides of the seats. Because the sides of the 2nd row captains have this shaping to them, they cannot fold as flat. The material from the side seat support hits the base of the seat, preventing it from going flat. At least this is what I have blamed for it.Really disappointed the seats don't fold flat, travel quite a bit and always carried the cooler on passenger side fold down in my Enclave. Looks like plenty of room for it to collapse all the way. Might just have to take the trim on the side apart and see how that latch works.
I took the trim apart this afternoon and took a few photos. Point A is the stop that prevents seat from folding all the way. Point B is the stop that prevents the seat from lying flat in a fully open position. C is a curved piece of metal welded to the seat back frame and travels between the stops as you fold or open the seat. There is an identical layout on the opposite side of each seat. I"m sure you could remove C and the seat would fold quite a bit more than it does, but not completely flat. Not sure what impact it would have on the open position, although at the latch point before fully back it seems solid. Can't see if there is a latch point at fully back or if it just stops against B. Screws under each of the lower handles to remove trim, then good set of trim tools to pry the pieces apart at the rear of seat. Annual grouse hunting trip coming up pretty quick, will decide if I break out the grinder or hacksaw after the trip.Really disappointed the seats don't fold flat, travel quite a bit and always carried the cooler on passenger side fold down in my Enclave. Looks like plenty of room for it to collapse all the way. Might just have to take the trim on the side apart and see how that latch works.
Its not the material holding it up, its an actual support Subaru has placed in there so the side bolsters don't get smashed and deformed.I believe it has to do with the bolstering on the sides of the seats. Because the sides of the 2nd row captains have this shaping to them, they cannot fold as flat. The material from the side seat support hits the base of the seat, preventing it from going flat. At least this is what I have blamed for it.
It is too bad that they couldn’t have the seat base tilt forward when folded to retain the seat side support and still have a flat platform. My Flex 2nd row captains folds flat but the seats have minimal shape to them.
propane cutter anyone?I took the trim apart this afternoon and took a few photos. Point A is the stop that prevents seat from folding all the way. Point B is the stop that prevents the seat from lying flat in a fully open position. C is a curved piece of metal welded to the seat back frame and travels between the stops as you fold or open the seat. There is an identical layout on the opposite side of each seat. I"m sure you could remove C and the seat would fold quite a bit more than it does, but not completely flat. Not sure what impact it would have on the open position, although at the latch point before fully back it seems solid. Can't see if there is a latch point at fully back or if it just stops against B. Screws under each of the lower handles to remove trim, then good set of trim tools to pry the pieces apart at the rear of seat. Annual grouse hunting trip coming up pretty quick, will decide if I break out the grinder or hacksaw after the trip.
